Help With XS3 settings.....
CA
Newbee here needs some more help........
what are your xs3 th (throtle settings..)?
what are your xs aux settings?
My st settings are good but my throttle and aux is all badddddddddd.......
I'm having hard time starting it seems that when i give alitte gas it applies brakes and when the truck starts the rpm goes sky rocket at neutral position, it seem that it also engages reverse...
Please help......cant break in the mottor like this....
RE: Help With XS3 settings.....
There is a setting as you scroll through the menu that says something like "norm----rev". Sounds like you need to change both of these on th and aux. Just switch to the other one. You then need to adjust all your EPA's (end point adjustment). Hope this helps.
CA
uhhhhduhhhhhhhh..... you are right on the MONEY............... I'm voting for you next time.......... thx....very very much
ON, CANADA
I'd like to Help with the Radio Settings.......But There Probaly way off from yours......(As in EPAs and such)
Just make sure your On the right Cannel on the Radio as the Receiver,
TDB at 0%
EXP-THB/THF= LN
EPA's you'll have to set so you Got Brakes/Gas with Carb opening all the Way/& Aux (Rev Servo) So it'll Hold it in Gear.....
MIX-0% on both
Trim THS= 0
TH = REV
That may Help?
TDB at 0%
EXP-THB/THF= LN
MIX-0% on both
Trim THS= 0
TH = REV
That may Help?
