Tubbed Aftershock Pro-Stock!
MI
Tubbed Aftershock!
Losi Aftershock
Scale: 1/8
Drive: 2wd
Trans: Stock
Width Rear Wheels: 10 ¾”
Width Front Wheels: 10”
Wheel Base: 18” (stock 14”)
Rear Wheels: Pro-Line Mambo 40 series
Front Wheels: Thunder Tiger 1/5 Ducati 999R Motorbike front tires
Pinion Gears: ?
Spur Gears: ?
Engine: Mach 28
Pipe: ?
Winter project in the works! Your feedback is welcomed.
Losi Aftershock
Scale: 1/8
Drive: 2wd
Trans: Stock
Pinion Gears: ?
Spur Gears: ?
Engine: Mach 28
Pipe: ?
MI
RE: Tubed Aftershock Pro-Stock!
We need a Pro-stock body to fit:
18” wheel base
11 ½“Rear with and 11” Front with
Can you help? I am not having much luck...!
18” wheel base
MI
RE: Tubbed Aftershock Pro-Stock!
iexion,
Thanks for the support! It’s always nice to hear something positive. All I can say is, “I hope it pulls the wheels”.
MI
nitro _ burner,
I don’t know at this time. I am also into airplanes and nitro boats, that’s where I got the idea from. I assume it will work fine, however until I try it I will not know.
Thanks for the interest!
This is someone who definitely knows how to... " draw outside the lines "
This does make me wonder just what type of body you would want to fit on this... Machine
But that should be kept a secret[>:]
MI
No not yet. I am still waiting for the front rims. I hoped to get them before Thanksgiving, you know how that goes “no such luck”. I am working on the front shocks and will post pictures as soon as I can.
Alright sweet. Do you want this for top speed or dragster because that will defanetely determine what kind of pipe you will need. I think stick with your engine now to save some money and get some other good stuff. ( pipe radio etc ) You really don't need to have a new engine the mach is fine considering the little amount of weight you are going to have. Wich can make you gear it alot higher.
