Is this normal..?
![](/forum/images/badges/trading_plus_member.png)
FL
Finally got all the part`s for my (USED) Lst...! Almost ready for the first run..but I noticed the rear axle has alot of play...was wanting to know if this is missing any shim`s or is this normal...I bought this thing with no manual and been getting alot of help from the tread`s...thank`s for all the advise
Silly question, but are you sure the hex is pushed on all of the way? You can still see some of the axle pin. Otherwise, that is a ton of play. You sure the inner bearing is in too?
That is too much play, something is wrong. Something ain't jivin. Have you looked at exploded diagrams and made sure you have all of the parts on right? I would expect a few mm in play, but no more then that. If it is put together right then look into some shims. It will be sloppy like that.
FL
Silly question....NOT...Well I took your advise and BINGO...there was so much of crap stuck in the hex...it looked like it was all the way in but when I had to pry it off I found it was packed with mud or som-n..? Problem solved..! DUH...easy fix..wish they all were that easy... Maybe I`ll get some 23mm hub`s...! This thing might run today...Good job....THANK YOU
