THE GREATEST AFTERSHOCK THREAD EVER!!!!!
#101
RE: THE GREATEST AFTERSHOCK THREAD EVER!!!!!
Somebody throw a dog a bone here. How many turns out are you all at (LSN and HSN) on your M26SS w/ HT pipe? Help a brother out here!
#103
Thanks for the reply. That's about where I was before swithching from the stock crappy pipe to the HT pipe. Maybe retuning won't be so bad then. 150* is as cool as a cucumber. Does it make good power at that temp? Are you running rich at 150* ? Thanks again.
#104
it is safe to run that engine at 220. i believe in the manual losi says 230 is a good running temp. once you reach 200 you will notice that engine has HUGE power. i find below 200 the engine is too slugish.
#105
AE
ok, i have a problem with my truck. when i put the brakes on it dies so is there any way to fix this? i have the throttle screw set to factory set if that helps.thanks
jake
jake
#108
ON, CANADA
ORIGINAL: evad1
jake
jake
#110
hey guys nice shocks, do any of you guys have problems starting ur shocks at this time of year, cause idk if its the weather or somthing, but if it is, how do i solve the problem. and i do not plan on putting it away till i see some snow
#111
hey guys i got my shock about a month ago and its great i got the hard ano. HT pipe that thing brings the m26 to life , but i am recently having a problem when i run it WOT and then stop back to idle the rpms get high then when i blip the throttle a little it idles back to normal please help.
#112
My Feedback: (54)
my 2 different after trugguys, and 1 mini mgt
1 jof the rigs has the traxxas water proof servos on it and a ballon on the throttle servo. works very well for winter running.
#114
Aftershock pics. Aftershock with Savage Xl wheels/tires 17mm hexes, LRP 28, JP3 pipe, wheelie bar, LST2 body, RPM arms and head protector. Soon to come new era roll cage.
#116
