engine brace
FL
RE: engine brace
who had one break. and what were you doing when it broke. I have the brace on my list of things to get but im not to worried about it. I dont jump 20feet up and crash land. but i guess it still lands hard alot . how easy are they to break?
GA
RE: engine brace
Really, really easy. YOu may even look at it and think its not broken until yu really, really inspect it.
When it does break, it will let the alum engine plate bend, change mesh and maybe ruin both your pinions and spurs and clutchbell bearings
Dont gamble. $14 is CHEAP insurance, and is really all you need to get your LST2 bash strong
FL
RE: engine brace
ORIGINAL: IL2mSturmovik
RE: engine brace
i agree, the stock engine brace is very strong. i admit, the machined aluminium one from dynamite is probably stronger, but you would have to bash your vehicle extremely hard to break that engine mount. unless your doing some extreme stuff i dont think you ahve to worry. i drove on the road, and on grass an go off small jumps and my stock engine brace is holding up well. but i might upgrade just for the look of the blue aluminium
ON, CANADA
RE: engine brace
The Stock One will Crack Pretty Easy if you Bash Hard.........Most Don't Notice it's Broken till they Strip there Spur Gears..........
GA
RE: engine brace
ORIGINAL: buck hunter
i have the stock engine brace on my shock for 1 1/2 years, bash hard and never broke it.
Go look.
Thoroughly, because it can appear to be a casting line or in shadow or something.
If you bash hard, I would be very suprised if it lasted 2 sessions
RE: engine brace
i checked, mine is ok. i mean i dont go crazy with my vehicle. very tame compared to the things i see posted. but i think i will order the blue dynamite engine brace eventually. i am in no hurry because mine is ok and the weather sucks, so i have not got alot of time in for bashing. thx for the posting on the issue tho.
CT
RE: engine brace
mine is still good but have the dinamite engine brace in a drawer , i bash moderate and have taken it to he track a few times and its still good. it cant hurt to change it at a later date if you just got the truck and just want to run the stock brace for a gallon or so. like i said mine is 1-1/2 years old and still running the stock brace i probably will change it this year but thats after 6 gallons of fuel through the truck.
GA
RE: engine brace
ORIGINAL: jombo
Thats what I did, and it costs me plenty.
Learn from my mistake
RE: engine brace
Yeah, the engine must come out, to access the 4 of the screws holding the brace in.
To those guys saying they have the brace but not installed yet, or nah mines still ok, this thing costs $14 or so, and could save you plenty, cheap insurance I say, was the first thing i did to mine
FL
RE: engine brace
no doubt i am putting mine on,finished breaking it in last night,tonight i will tear it down,check/tighten,re loc-tite,and install the engine brace.have not priced it yet,but that pinion setup on this looks kind of expensive[:@],no chances here
LA
RE: engine brace
well ive had my lst 2 for over a year, and i keep it really clean after running it. the other day, i hit a jump and bent a shock shaft. i took the shock out, and while i was at it, i removed the engine cause i had the dynomite brace sitting here. the stock brace looked perfect, till i un bolted it. it came out in 2 pieces. so i advise those who have an lst2, even though the brake looks good, remove it. like i said, mine looked perfect. couldnt see a crack or break anywhere. when i unbolted it, bingo, came out in 2 pieces. replace the brace even if it looks ok.
RE: engine brace
After attempting my first back flips to day () and landing a few upside down i voticed my engine brace cracked. Im not going to run it till i get the Dynamite one!
WA
RE: engine brace
First thing I did o my AFT was to change out that engine brace. Didn't even start the engine once.
I just finished upgrading to the Ti-Ni spur and pinion gears, and it wasn't cheap. If you upgrade to those, and don't do the engine brace, then it cracks and screws up the gears, you will be out around $90. Not worth taking the risk, when a $14 part and 15 - 20 minutes of work can give you some extra insurance. I would suggest doing it first thing.
RE: engine brace
IL2mSturmovik & Sugafree are both 110% correct.
I kept thinking the same thing " i dont bash hard and mine looks fine "
but once i took off the engine and took the center chassis plate apart i then saw it was cracked and sure enough it was broke. I was wondering why my spur/clutch gears kept stripping so easy. So it really is something worth buying (dynamite engine brace ) because you dont really know what will keep breaking/grinding. its worth the $15 bucks just to get it IMO. Im also looking into more dynamite products to "color theme" my truck
GA
RE: engine brace
Yesterday at the race, there were 2 Losi truck guys, one with a Mega Baja, and the other with an Aftershock.
I cautioned them about it, and when we looked at theirs, one was cracked but very hard to tell, and the other had broken in half, and the bottom half was gone and the 2 screws that held it in [X(]
This should be automatic for every new Losi truck, replace that brace before you even start it
RE: engine brace
Does it make much difference it you were to use the Integy one or any other as long as its machined rather than cast like the stock one?
Or is the Dynamite one the only one to consider?
GA
RE: engine brace
IMHO I would not use almost anything Integy.
Dynamite or GPMs http://www.amainhobbies.com/product_...ducts_id/12482
IMO the DYnamite is the strongest however
RE: engine brace
That GPM one looks weaker the the dynamite engine brace, altho it is a bit cheaper. still would have to say the dynamite brace is the better of the two.
