Spur gear
CA
Spur gear
The only things I have broken up until now are the pipe mount rod and the right front spindle. I've broken the spindle at least 6x. Maybe I should go with the aluminum spindles. But now I have stripped the low speed spur gear twice, the second time happened literally on the run after I repaired it. What causes this, I have no clue as to why this happens. Can anyone help me out with this?
RE: Spur gear
Seems to me that you're not getting your gear mesh set correctly.....another thing to check is make sure the gears are properly aligned- the gear shaft and motor shaft are parallel....
GA
RE: Spur gear
ORIGINAL: Airbus 9e
Yes, and get alum spindles.
It seems the last few months of spindles are horrible brittle.
My original spindles lasted the longest, then the 2nd set lasted a while too, bu the 3rd-5th were like glass.
New Era alum spindles=answer
GA
RE: Spur gear
ORIGINAL: bigtreds
check and see if your engine mount is cracked. could be striping your gear. if its cracked it will flex under power.
CA
RE: Spur gear
While taking the truck apart, I discovered one of the 4 bolts holding the engine down was missing and 2 others loose. Would this cause the gear to strip?
GA
RE: Spur gear
ORIGINAL: Griffsred
While taking the truck apart, I discovered one of the engine mount bolts missing and 2 others loose. Would this cause the gear to strip?
As surely as teh sun rising tomorrow
CA
RE: Spur gear
Guess I should get aluminum spindles, aluminum spur gear(low and high?)Maybe engine mount as well. Am I missing anything else? Other than those 2 parts the truck is great,and now that I discovered it was a missing engine bolt not just a brittle gear. I'm not really feeling the need to add much more. You guys disagree, agree?
RE: Spur gear
No one make aluminum spur gears, but the spindles and engine chassis brace are good ideas. My stock spur gears keep stripping because the little screws get pulled right out of plastic, and makes an awfull mess. I hate using titanium gears because they are so thin they cut into and wear out clutchbell gears. I can't win! I am using the losi +1 clutchbell and highspeed titanium spurs(I think they are-4 teeth?)and wear out clutchbells within about 1 1/2 gallons. Tried stock gearing, and it kept pulling screws from spur gears in about 2 tanks. Getting tired of so little gearing options with this, and I'm not paying 8mans prices for pinions, that is crazy high! I'll figure something out yet!
PA
RE: Spur gear
ORIGINAL: CBM Racing
