Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
Pipe fitting
Old 04-16-2008 | 10:54 AM
Wisconsin Nitro's Avatar
Default Pipe fitting
the part were the pipe is connecting to the tube that connects to the engine is not on all the way
like its on sorta but there is not sitting flat to the tube and its off a llitle so i believe im loosing compression in that area if it matters
does it matter and how would i fix that? currently i have the 3 springs on it and its in a sort of triangle fasion
its hard to exlpain with out pics so i hope some of you get it
Old 04-16-2008 | 10:56 AM
Default RE: Pipe fitting
its here in this area and think of the header as going traight but the pipe is going off at an angle a little bit
Old 04-18-2008 | 06:37 PM
I used rubber sleeves that are good for 350+ F to fit over the header for my HP pipe and then zip tie them on. It seems to work well
Old 04-19-2008 | 12:02 AM
full maxx's Avatar
the three springs are correct but you need to take them off and see if the exhaust gasket is whole or torn ... if its danaged go to your lhs and get another one and replace it
