Forward only conversion instructions
Here's an exploded view from the Losi web site. Looks pretty simple.
http://losi.com/ProdInfo/Files/LOSB3130.pdf
Major reduction of rotating mass....more bottom end and more top end....oh btw when you have the trans open, don't forget to do the FOC gear swap which can give u same effect as +2 pinions
yeah i just did this and my truck hauls. It is a big difference. It will help switching the gears. Make sure the gold gear is on top. you wil have to shave it out to fit with a dremmel. But when you get it fit properly it work fine and you have about 4 mph more on the top end.
ORIGINAL: joshreynolds777
I have no Idea what an FOC gear swap is!?
Interested to know tho.
Also, will the LST with the factory 26 out run a revo 3.3?
