Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
2-speed problem
Old 05-15-2008 | 06:49 PM
Default 2-speed problem
I just got new 2-speed clutch shoes for my aftershock. When I run my truck it takes like 15 min of WOT passes for it to shift and when it does the shoes slip on the shaft. After that happens my truck goes faster like it is in 2nd gear but it doesnt shift. What is the problem?
Old 05-15-2008 | 07:16 PM
Default RE: 2-speed problem
It sounds like you just need to tighten the center screws in clutch shoes, the ones with the little ball inside there.
Old 05-15-2008 | 07:53 PM
Sugafree's Avatar
If your Still Using the Stock Aftershock Spurs Chances are they are the Problem.........Up-grade to the LST2 Alum Hubs and Spurs and It should Shift Fine.......
Old 05-16-2008 | 05:21 AM
Can somebody give me a link.
Old 05-16-2008 | 05:25 AM
Will this be good for bashing and will it work?
[link]http://cgi.ebay.com/LOSI-LOSB3432-HIGH-SPEED-TiNi-CONVERSION-GEAR-SET-LST_W0QQitemZ290230868881QQihZ019QQcategoryZ44028Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem[/link]
Old 05-16-2008 | 06:38 AM
atv_motocross#38's Avatar
no, those are only to add strength to the drive line, they wont help it shift. There are four losi part numbers that are on the lst2 page (losi.com)
Old 05-16-2008 | 12:17 PM
Sugafree's Avatar
It's Cheaper to Find the Full LST2 Set up on E-bay.......But I'll Give you the Links to Killer,
2-Speed Low Gear Hub w/1-Way
2-Speed High Gear Hub w/Bearing
70T Spur Gear, Low Gear
63T Spur Gear, High Speed
