Aftershock pipe?
GA
Aftershock pipe?
Ok i've been reading thru the threads trying to find out the best pipe for the aftershock, some say RDlogics duel stinger, some say LOSI HT, but i haven't found anybody to compare these two? which is better?, and yes the buku is the best but i cant afford it right now. I just want something to wake up the stock .26 for now and then when i save up some money, LRP .28, bukupower pipe.[8D]
WI
RE: Aftershock pipe?
hey man, ur in the same boat as i am. do not get any integy pipes! loud and bad performance. im getting the polished ht pipe from losi. i would also say the stock lst2 pipe is a good one. any losi pipe than the aft. pipe or mega baja pipe is prolly ur best bet.
WI
i HAD rd logics pipe. loud and cool sound but crappy power and i could keep a simple tune cuz the crappy compression int the pressure line. kinda on/off power.
RD LOGICS=[:'(]
LOSI=
RD LOGICS=[:'(]
LOSI=
GA
ok now, with the losi HT which is better- hard anodized- or -polished-? i mean i know there both HT pipes but does the finish of the pipe make any difference?
AZ
Get the hard anoe'd pipe. It is a breeze to keep clean and produces more power than
a regular aluminum pipe. Beacuse this a hard coating it will produce a stronger return
pressure wave than a standard aluminum pipe which being a softer material will absorb
some of return pressure wave's strength. Steel is probably the best material for a tuned pipe
because of its rigidity and heat holding ability which aids in more efficient combustion. Why do
you think all the trick "factory works" style motocross dirt bike pipes were made of steel ?
If you are not smelling nitro fumes and listening to the sweet song your not LIVING !!
