LST2 clutch springs- somthing softer?
IA
Is there any clutch springs for the LST trucks that have a softer clutch spring? It seems like the stock springs are stiff as can be. It wants a lot of throttle to get going and I want something were I can ease in to the throttle to get going and were its a little easier coming out of turns so I don't break loose as much. I do have composite/plastic shoes in it now, but did have aluminum before and didn't have any noticable difference. Thanks
a
a
RE: LST2 clutch springs- somthing softer?
You dont want to go too soft on the springs. Usually stock springs are the softest and most upgrade to stiffer ones. The Springs that come in the HPI savage are pretty soft. You may want to try them.
