LST2 - Throttle servo problem
Just go to your throttle controls on your handheld. I think you hit channel until you get to your TH controls then then scroll until you find TDB. Once you lower it you will be able to see if your throttle servo slows down.
www.modelflight.com.au
– World’s best source of JR productsxs3 5 10/31/02 3:13 PM Page 21
Function Mode
Throttle Deadband
Accessing the Throttle Deadband FunctionThe throttle deadband feature is used to reduce/eliminate the
dead throttle area that exists at neutral to the starting point of
throttle and from neutral to the starting point of braking. This
area is sometime known as deadband. As more throttle trim
(also known as static brake) is applied, more of the dead
trigger area right off neutral exists. To eliminate the throttle
deadband, adjust a forward value such that your vehicle’s
wheels just start to turn when the trigger is slightly squeezed.
This provides the most accurate feel and eliminates the dead
area in the throttle. To eliminate the braking deadband, adjust
the brake value such that your
ENTER
SCROLL CHANNEL
CLEAR
INCREASE DECREASE
Press the
screen.
Press the
desired value necessary.
Scroll key until "TDB" appears on theIncrease or Decrease key to select thevehicle starts to slow down when the trigger is slightly
pushed. This provides the most accurate brake feel and
eliminates the dead area when braking.
tdb
1.
Turn the transmitter power switch on.2.
Press the Scroll key to access Function mode.3.
Press the Scroll key until "TDB" appears on the screenL/F
08Forward Adjustment
(depends on
trigger position)
4.
braking deadband.
Move the trigger accordingly to adjust the forward or5.
Press the Increase or Decrease key to select the desired Current Valuevalue necessary to eliminate dead area.
tdb
0
8Brake Adjustment
(depends on
trigger position)
6.
Press the Scroll key to access the Exponential function.7.
power switch or press the
same time.
To exit the Function mode, either turn off the transmitterScroll and Channel keys at theR/B
Current Value
Values: 0% to 100%
Clear = 0%
21
