Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
Tuning Problem Please Help!
Old 03-03-2010 | 07:19 PM
Default Tuning Problem Please Help!
Hey guys I am a noob to the RC world and bought a XXL a month or two back and am now started to play with it since the weather is getting warm. I have a problem right with the tuning. I get the truck to idle fine. The problem comes when I get on the trottlethe idle sky rockets and wont come back down to the normal idle whereit should be at. Theidle isso high that the truck actually goes about 3 MPH whenI am not eventouchingthe throttle, I then have to run over to it and kill it. It happens every time and I dont know if it is my idle, high speed or low speed adjustments. Any help on this would be greatly appreciated.
ANPACMN
Old 03-03-2010 | 07:59 PM
bigblock454XXL's Avatar
My Feedback: (-1)
Default RE: Tuning Problem Please Help!
Um. . . Have you adjusted your idle at all? It's been a year since I did the break-in on mine. Now I just adjust the high speed needle to the weather. I'd say put them all to stock settings and go from there. I think if you look in your carb it should be open just barely.
Old 03-03-2010 | 08:02 PM
My Feedback: (-1)
My idle is set at 3/4 turn from flush. If that helps.
Old 03-03-2010 | 09:38 PM
I checked the idle and I was a whole click from flush. The problem is still there. Is there anything else that could cause this reving problem?
Old 03-03-2010 | 10:04 PM
My Feedback: (-1)
Is your throttle linkage binding at all? should be a straight shot and mostly level.
Old 03-03-2010 | 10:48 PM
Argess's Avatar
You are running the HSN too lean. When you do a WOT run, and then let off the throttle, the engine won't idle down right away as the mixture is still lean. With a correclty adjusted LSN, the idle will eventually die down to normal as the mixture richens up after a while.
Open the HSN up about 1/4 turn (rotate CCW)and see what happens.
Here's a video of a mild case of your trouble. The "High Speed Too Lean" banner starts around 0.55 seconds into the video. Start paying close attention around the 1:00 minute mark. Notice he drops the throttle around 1:07, the idle stays high, then it drops to a normal idle at 1:10
http://www.youtube.com/watch?v=BJFsJ...eature=related
