Diff fluid
I have an Aftershock with a new Losi 454 and I want to take the grease out of the diffs and put silicone fluid in them. What weight would work best in them, I don't race or hill climb.
Thanks, Randy |
RE: Diff fluid
30K front and rear is a Good spot to Start for bashing....
RE: Diff fluid
sugafree Why run 30 weight instead of say 10k? Does the thicker oil make the diff work more like a "locker"? or does it just wear on the case less with thicker oil The reason is all I do is bash as well and I was about to replace the stock grease with traxxas 10 weight. Also, how much oil do you put in. Do you fill the case or just put in enough to lube the gears. Lastly is there a particular brand you recommend?
RE: Diff fluid
10K will be fine if that's what you got ;) (Lots of races use 10K) As far as Brands......I Like Ofna Diff-lock
Here's some thread to check out, Diff oil for bashing? How to, Silicone diff fluid How to rebuild and shim a LST2 diff |
RE: Diff fluid
I use 30,000 WT in my XXL. The difference between that and grease is like night and day, Before If I turned the wheels fully and hit full throttle, the front inside tire would immediately diff out and grow huge, Now with 30K oil doing the same thing it just goes and the tire doesn't diff out... I haven't tried 10k because I'm happy with the 30k, but I would say on a monster truck, you want to go thicker than you would on a truggy, since MT's don't steer well when you are going fast anyway, you don't have to worry about losing steering to the thick fluid....
RE: Diff fluid
I have the Traxxas 10k in both my diffs, and it is still way better than the stocker grease. Go for it.. you'll be glad you did. My diffs are both totally filled with fluid. I havent had any trouble yet...
RE: Diff fluid
Great info guys thanks. I will probly get some 30k. I'll use the 10 k in my aftershock and the 30 in my lst. That way I at least don't waste the 10k. The aftershock is my backup truck.
RE: Diff fluid
oh yea, as for how far to fill, you want to fill it so it just covers the cross pins in the diff... Don'T worry though, all that will happen if you fill it too full is it will squish out when you put it together... just do it over the sink....
RE: Diff fluid
I was wondering about that. I should get my new inner cases today. Put it together take it apart, put it together take it apart.[&o]
It is my back up maybe I'll wait till after the weekend. |
RE: Diff fluid
im tight on cash right now so i would like to know if i can use 10W-30 motor oil(for 1:1 cars) to fill my diffs ?
RE: Diff fluid
no, its too thin. Plus, if it leaked, you would have oil all over... I would rather have silicon oil than motor oil in the back of my jeep/in my house/etc...
I mean, I guess you really could and it would be a little better than grease, but honestly, a bottle of diff oil is like $6..... |
RE: Diff fluid
I tore my rear diff apart, Cleaned it up spotless then JB welded the in side of the diff togeather. Let it dry a couple days then re installed it. Completely locked now and i love it.
RE: Diff fluid
I don't think I'll lock mine but I'm curious as to what part you JB weld to lock it? Any pictures?
RE: Diff fluid
jb weld these four planitaries http://i211.photobucket.com/albums/b.../Capture-1.jpg
RE: Diff fluid
Oh.
RE: Diff fluid
I got me some 30k yesterday and will change it out tomorrow after changing out a condensing unit (I love overtime)
RE: Diff fluid
ok well I finally got to drive it today and it still seems to spin the front inside tire when coming out of a turn 30k front and rear
RE: Diff fluid
ORIGINAL: full maxx ok well I finally got to drive it today and it still seems to spin the front inside tire when coming out of a turn 30k front and rear |
RE: Diff fluid
swaybars installed already...not sure I want to lock it at least not permanent
RE: Diff fluid
I wouldnt lock it. Locked diffs belong on rock crawlers. If you want to keep good handling, you need some diff action. If the tire didnt unload a little, you would just traction roll....
RE: Diff fluid
Ok is there anything heavier than 30 k? can you go to a 100 weight or would there be too much drag?
RE: Diff fluid
no it wouldnt be too much drag, the gears in the diffs only move when you turn.
RE: Diff fluid
I have seen 125,000
RE: Diff fluid
Here is a link to 500,000. Anybody ever used this????? Has to still be better than grease.
http://www.amainhobbies.com/product_info.php/cPath/1_167_297/products_id/6935/n/Kyosho-Silicone-Differential-Oil-(500%2C000wt)(40cc) |
RE: Diff fluid
ORIGINAL: MidMichigan Here is a link to 500,000. Anybody ever used this????? Has to still be better than grease. |
| All times are GMT -8. The time now is 12:37 AM. |
