Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Micro DH2
Old 09-28-2010 | 04:17 PM
Default Micro DH2
Hi Floks
My son Scott and I have just got back into RC planes, and flying this last year.After about 10 years of off time, it was the new Parkzone backyard flyers that got us back into the hobby. Starting with the Ember, then the Cessna, then the E-flight4-Site, then bacl toParkzone Mustag. But after the Cessna we wanted to build small. We started of with the guts from a Ember and made Thayer's Micro Drake. Itflies well and it does take off from, and lands on water. Then Scott and I, tried building a 1/26 scale Fokker DR 1 it didn't fly at all. Then Scott remembered the half done DH2 40" wing span in the atic. He started from scratch build 1/26 scale foam DH2 with carbon fiber struts, and guts from the Ember with string controls, it didn't fly well, but it flew.Picture below.
Old 09-28-2010 | 10:24 PM
Default RE: Micro DH2
Hey mod
Cant make pic enlarge to see it!!
Can you post pic again and see what happens.
From what little can be seen in the small pic it looks good.
Old 09-29-2010 | 08:05 AM
Hi Dave
Well I have another picture of the next DH2 that we did. I went with bell cranks around the push engine and it flew real nice used the guts of the Ember. The picture is of me holding the DH2, the color job is sharpies but we are looking ahead on this plane. I will post some video of thisplane I'm holding flying.
Keep on flying
Scott and Mike
ID:	1508379   Click image for larger version
ID:	1508380   Click image for larger version
ID:	1508381   Click image for larger version
ID:	1508382   Click image for larger version
Old 09-29-2010 | 04:31 PM
This is a video showing that our proto type 3ch flies </p>
http://www.vimeo.com/7339320</p>
ID:	1508525   Click image for larger version
ID:	1508526   Click image for larger version
ID:	1508527   Click image for larger version
Old 09-30-2010 | 08:05 AM
This is one of aircraft, DH2, that ended the "<font color="#0645ad">Fokker Scourge</font>" in WW1. Scott and I had to make it look better now that we knew that we could make it fly. We learned about printing on foam and found a printer that could it. Got into a cad program and Scott did all the art work in the cad program and we printed out the plans for the next DH 2 airplane. This time we wanted it look better and fly with four channels we used the guts from a Parkzone Mustag.
Old 10-02-2010 | 02:06 PM
This is the upper wing....it is 1mm printed depron.
This is printed straight to the foam after it was airbrushed with Inkaid.
We thinned the inkaid about 50% water 50% inkaid. Furthermore I didn't weight before because I coated a whole sheet of depron then cut three 14"x13" sheets after it had dried. If you do a search on inkaid someone has this information.</p>
</p>
Old 10-03-2010 | 12:37 PM
This is a test body so I could make the nose plug the right size. I plan on molding the nose out of light clear plastic and airbrushing it the right color.
Old 10-03-2010 | 05:18 PM
Wheelnut's Avatar
My Feedback: (81)
Nice work. I'm lurking
Old 10-04-2010 | 12:40 PM
Hi Wheelnut
Lurk away
This is our third attemp at a nose and some strut construction. Note that the struts have the color scheme on both sides and the nose is taped for a test fitting.
ID:	1510926   Click image for larger version
Old 10-04-2010 | 05:07 PM
Wheelnut's Avatar
My Feedback: (81)
Now that's cool.
Old 10-05-2010 | 08:19 AM
Hi Wheelnut
What we got out of an evening of vacuum forming practice. Now its off to figure out how to get the right paint color.
Old 10-05-2010 | 08:27 AM
Wheelnut's Avatar
My Feedback: (81)
I thought that nose was vacume formed. at first I thought you may have bought it, but you guys are doing it yourself, very cool.
Old 10-05-2010 | 02:31 PM
For the wheels most WWI aircraft had hubs on different color.
we used these wheels perfect scale. I used black marker and glued on
red hubs the next one I'm going to paint black, but they looked good
on the first DH2 pictures above.
Old 10-06-2010 | 01:57 PM
I just wanted to post some color pics of some of the assembly steps and inner workings.
This is the bell crank for the rudder and the reused Parkzone mustangaileron bellcrank mounted on the floor peice. We are using thread for the rudder and elevater pull pull set up like the real DH2.
ID:	1511929   Click image for larger version
ID:	1511930   Click image for larger version
ID:	1511931   Click image for larger version
ID:	1511932   Click image for larger version
ID:	1511933   Click image for larger version
Old 10-06-2010 | 07:04 PM
Wheelnut's Avatar
My Feedback: (81)
I see a plane coming together
Man that's some mind numbing tiny detailed work[X(]
Nice work!
Old 10-08-2010 | 07:22 AM
Now the wings and struts, easy to do, takes a little time not much. It's the 200in. of carbon fiber that makes this model work. This is a scale models to. The 1mm foam is easy to cut out with sharp sisscors, or exato knife. We used the string for the rudder and elevator pull, pull system no small pulleys but glass beads worked well in picture three.
ID:	1512698   Click image for larger version
ID:	1512699   Click image for larger version
Old 10-08-2010 | 07:34 AM
Wheelnut's Avatar
My Feedback: (81)
Ahhhh..... starting to look like a plane. Nice! I don't like that level of detailed work too much. I don't have the patience
Old 10-10-2010 | 08:17 AM
This is easier to build, than the Guillows kits, I use tobuilt. First you cute out all the foam parts, then you cut the carbon fiber and build the struts and boom body I have template for this so they are the same every time. My son Scott wants me to make a kit of this.
ID:	1513866   Click image for larger version
Old 10-11-2010 | 02:54 PM
After you have the sturts and boom body done, and the body put toget with the controls inside you attach the lower wing to the body and add the struts to the lower wing with the cross carbon fiber. Then you stand the plane on the flat part of the nose and add the boom body. You will notice that 1mm foam parts are glued to both sides of the struts over the carbon fiber. It makes it look real cool. The struts are added to the wing when the plane is shown in the first photo.
ID:	1514847   Click image for larger version
ID:	1514848   Click image for larger version
Old 10-11-2010 | 05:36 PM
Wheelnut's Avatar
My Feedback: (81)
Man! put the plane together already[:@] What's taking so long, it's been like two weeks now right??[>:]
Just kidding. lol. Looks like it's going well.
It would probably take me a month or more
Old 10-12-2010 | 09:25 AM
Here are some pictures of the back of the boom body, with the 1MM foam on the sturts to make it look likethe real paintedwood. This foam is also around the wing struts. The nose of the DH2 is held on by magnets and the battery goes in the nose to keep the CG as far forward as we can, and if you have to add weight it would be here in the nose. Wheelnut it's taking more time to take pictures, and write this blog than to build the DH2.</p>
ID:	1515308   Click image for larger version
Old 10-12-2010 | 04:47 PM
Wheelnut's Avatar
My Feedback: (81)
I like the magnets. I'm starting to see them on more and more applications.
I know one guy that is starting to use them to hold on his cowl
Old 10-13-2010 | 05:01 PM
ORIGINAL: modesigner
This is easier to build, than the Guillows kits, I use to built. First you cute out all the foam parts, then you cut the carbon fiber and build the struts and boom body I have template for this so they are the same every time. My son Scott wants me to make a kit of this.
if you make a kit i will buy one!! just got the parkzone bnf mustang so i guess i have the electronics for it!!
Old 10-13-2010 | 05:44 PM
Hello Eagledancer
Scott, my son, and I have been talking about this and we have been thinking, $40.00 plus shipping that would giveus about
$1.00 and hour for our labor, but the plane looks to nice not to share. Whatdo you think?
Scott and Mike</p>
Old 10-13-2010 | 08:46 PM
Now for the elevator and rutter, both worked by pull, pull strings.
ID:	1516197   Click image for larger version
