Best Way to Attach a Canopy
I cannot speak from experience but I have read several times........ don't use CA to do a canopy. The fumes "smoke up", ( permanently stain), the inside of the canopy. Anyone ever have that problem??...... lownslo......
My Feedback: (45)
LA
You are mighty welcome Woodbutcher. I find it to be the neatest cleanest method there is and it is easily removable and it seals the canopy so fuel and dirt etc can't get in.
I used some stuff called "ribbon caulk". Made by 3M, available at automotive paint supply stores, and some "NAPA", Autozone, Advance,etc.. Fills "gaps", VERY tacky, holds well, stays pliable, easily rolled in to required thickness, easily removed, cleans up w/ alcohol, or most any other solvent. Does not harm the canopy, or covering. (So far.)
Allen
Allen
AZ
I am an idiot and used CA on my Magic extra ( my only excuse
was it was 1.30am and I really wanted to fly the next morning
lack of sleep = stupidity ) which of course fogged up the interior
and made it look horrible ( shame as the rest of the build was fine)
any suggestions as to how to remove the canopy without trashing
the canopy/covering job and clean up the stained covering inside ?
Christopher
Christopher
#31
Hi
Acetone disolves CA - I have a magic extra and splilled CA on the canopy and used acetone to remove it completely.
I was afraid that the acetone would affect the canopy but it was fine has not developed cracks or such afterwards.
Try putting acetone on the joint.
Tim
Tim
