 $12.88 and a few hours!!!! >
Old 05-12-2011 | 05:55 PM
Default $12.88 and a few hours!!!!
Well I some how found the time between getting the veggiegarden in, trying to finish a plane,starting dinner for the wife and mowing the lawn, to build a new flight box..
My old box was a monster, just way to big for the field I am flying at now. I don't have to walk far from where we park, so I made a new one.. I used the "MCS" program and it came out pretty good. I hit all the staple holes withbondo and got a coat of primer on it. The drawers are all done and I got the faces on drying over night. I will take some finished pics tomorrow...
ID:	1607787   Click image for larger version
ID:	1607788   Click image for larger version
Old 05-12-2011 | 08:10 PM
tacx's Avatar
Default RE: $12.88 and a few hours!!!!
WOW, Your old box must have been huge!
Old 05-13-2011 | 02:21 AM
MinnFlyer's Avatar
Where's the wet bar?
Very nice, but thinner wood could have made it much lighter.
Old 05-13-2011 | 06:15 AM
ORIGINAL: MinnFlyer
City code on the wet bar calls for 1/2"In all truth I would have liked to use 3/8 or 1/4 but i had 1/2" and didn't feel like making a trip..
I did save a bunch of weight by using a Cordless drill battery to power it, my old tractor battery weighed a ton..
Old 05-13-2011 | 12:11 PM
KitBuilder's Avatar
Very Nice.. you've inspired me. I haven't found a box on the market that I like that isn't 60 bucks or more so I may have to buld my own as well. Are you going to make a false bottom to keep the lower drawer elevated for easier opening in grass, etc? I find that when you pick most of them up loaded the weight isn't centered across the handle for example the fuel on the end wights down that side.
Old 05-13-2011 | 12:42 PM
ORIGINAL: KitBuilder
I was thinking the same as you, just didn't like anything on the market.. I basically laid out everything and built it to fit. The upper slot is not a drawer so to say, I have a plastic organizer for all my small stuff (ie. plugs, small tools and any thing else that is small), I just put aknobon it and it slides in like a drawer.The bottom drawer is only about 7" deep by 4" high and just slides on the bottom, the bottom is getting small feet to lift it up so it doesn't snag on the grass.The small 4" opening on the side is a prop drawer that will house up to 20" props and my retract pump..
You are right about the handle and weight not being centered, with all my stuff in and my cordless starter sitting on the right side, the pick up point it closeto the left side of the handle..
I'm waiting on paint to dry, so I will post pics once it's all done..
Old 05-13-2011 | 03:14 PM
tailskid's Avatar
My Feedback: (34)
Your building skills on that flight box exceed my building skills!!
Old 05-13-2011 | 03:23 PM
Paints dry!!!! I still have to mount my new fuel pump and load the rest of the stuff, put some stickers on itand it's ready to go..
Hey Minn, it's not as heavy as it looked when it was in primer.. It's a dream compared to my old one. I don't have pics of it but the wheels were from a hand truck, so that can kind of give you an idea..</p>
ID:	1608092   Click image for larger version
ID:	1608093   Click image for larger version
ID:	1608094   Click image for larger version
ID:	1608095   Click image for larger version
ID:	1608096   Click image for larger version
Old 05-14-2011 | 07:43 AM
Hi!
Looks good! But how much does it weigh?
Old 05-14-2011 | 02:52 PM
foodstick's Avatar
detachable wheels and a handle would be nice
but great build, you can tell you thought it out ...I doubt you leave any equipment at home !
Old 05-14-2011 | 03:20 PM
Nice looking box, I keep planning one, but when I get close, I buy more stuff to put in it. Like you, I use a couple of plastic boxes for drawers. A small bungee cord makes a real simple way to keep them in place when I move the box around.
Old 05-14-2011 | 03:55 PM
thailazer's Avatar
That is very nice! I like the walk-in prop closet.
Old 05-14-2011 | 04:59 PM
ORIGINAL: jaka
Hi!
It looks heavy but it really isn't, I haven't put it on a scale yet.. Powering it with a cordless drill battery really saved on the weight. I added a few more things to keep things organized, waiting on glue to dry. I will take some more pics tomorrow with it field ready..
Old 05-15-2011 | 08:18 AM
Ok, last pics, I promise,I'm just proud how it came out...
I had somescrap oak from a project so Imade a couple of hex wrench holders to keep them organized. It is all done now and field ready, as you can tell, I have a little more then a few hours in it now and about $22-25 bucks.. That includes the wood, paint, glue and what little hardware I used... The dims are 27" long X 12.5" wide and 12" high, it carries very well. If I had to guess on the weight, I would say 25-30 pounds fully loaded. My 10 year old son can lift it, so it got real light for me.
ID:	1608870   Click image for larger version
ID:	1608871   Click image for larger version
ID:	1608872   Click image for larger version
ID:	1608873   Click image for larger version
Old 05-15-2011 | 08:24 AM
ORIGINAL: foodstick
<span style="color: #ff0000">detachable wheels and a handle would be nice </span>
Got that covered!
I have a small fold down cart that works perfect.. I will keep it in the truck when i go to contest just in case I have a far walk, it also transports my kneel down pad and protects the box at the same time..
I been wanting to build a nice box for awhile now, I'm glad I finallytook the time and did it..
Thanks for all the nice comments, if anyone wants to know how I did something, just ask......
ID:	1608875   Click image for larger version
ID:	1608876   Click image for larger version
