Radiance F3A - new pattern kit
Old 03-30-2012 | 07:59 AM
  #51
Default RE: Radiance F3A - new pattern kit
As you can see, there's enough space inside the cowl for the OS33, but you would probably need to replace the standard exhaust with a tuned pipe.
Please keep in mind that the structure was tested with electric power only.
Old 03-30-2012 | 08:11 AM
  #52
More work on the stabs:
ID:	1744625   Click image for larger version
ID:	1744626   Click image for larger version
ID:	1744627   Click image for larger version
ID:	1744628   Click image for larger version
ID:	1744629   Click image for larger version
ID:	1744630   Click image for larger version
ID:	1744631   Click image for larger version
ID:	1744633   Click image for larger version
Old 04-02-2012 | 11:30 AM
  #53
Final operations on the stabs:
ID:	1745975   Click image for larger version
ID:	1745976   Click image for larger version
ID:	1745977   Click image for larger version
ID:	1745978   Click image for larger version
ID:	1745979   Click image for larger version
ID:	1745980   Click image for larger version
Old 04-02-2012 | 11:53 AM
  #54
MTK
The OS33GT is a powerful 2 stroke that produces considerable vibration. I would not put this engine in a plane without proper soft mounting. A hyde type mount set-up with 1" standoffs works fine. The minimum donut thickness should be 1" for better isolation.
Old 04-02-2012 | 09:47 PM
  #55
guille2006's Avatar
Alex; what servo are mounting on the stab? It's inside the stab; isn't?
Great Plane!!!
Old 04-03-2012 | 07:31 AM
  #56
ORIGINAL: guille2006
Great Plane!!!
Thanks Guille. Yes the elevator servos are installed inside the stab as illustrated in the attached pictures.
The hole in the supporting rib is dimensioned for the Futaba S9650 as it is probably the most popular choice for elevator servos.
It would be easy though to install any other servo of similar size.
ID:	1746308   Click image for larger version
Old 04-04-2012 | 08:00 AM
  #57
I attached a few pictures from the molding process of the cowl and canopy. The mold plugs were all CNC machined following the CAD 3D models.
ID:	1746642   Click image for larger version
ID:	1746643   Click image for larger version
ID:	1746644   Click image for larger version
ID:	1746645   Click image for larger version
ID:	1746646   Click image for larger version
ID:	1746647   Click image for larger version
Old 04-04-2012 | 08:02 AM
  #58
For the spinner, we decided to use a CNC machined mold and also a press tool to make sure the final part will run true without any vibrations. After the epoxy resin is cured, the excess material is also cut using a lathe.
ID:	1746649   Click image for larger version
ID:	1746650   Click image for larger version
ID:	1746651   Click image for larger version
ID:	1746652   Click image for larger version
ID:	1746653   Click image for larger version
ID:	1746654   Click image for larger version
ID:	1746655   Click image for larger version
Old 04-04-2012 | 02:02 PM
  #59
THanks Alex for the information on fitting the OSGT33 in the cowl. Thats very reassuring.
Also good work on the moulds. This is a very professional job. Thanks for bringing this very cost effective kit to the market at such a good level of quality.
Old 04-11-2012 | 06:42 AM
  #60
Last pictures before painting / covering, showing the assembled model with cowl, canopy and spinner fitted. Sorry for the low resolution:
ID:	1749192   Click image for larger version
ID:	1749193   Click image for larger version
ID:	1749194   Click image for larger version
Old 04-12-2012 | 07:12 AM
  #61
2 renders of the model with our suggested paintscheme:
Old 04-12-2012 | 09:58 AM
  #62
My Feedback: (45)
That is a great looking airplane. Very well done,
Arch
Old 04-13-2012 | 04:15 AM
  #63
Arch, thank you for the kind words. I'm glad you like it.
And now finally some pictures of the finished V2 and V3 prototypes. Tommie decided to switch the red and silver colors and it turned out pretty nice.
Please note that the kit version has longer ailerons and a different, better looking spinner.
ID:	1749693   Click image for larger version
ID:	1749694   Click image for larger version
ID:	1749695   Click image for larger version
ID:	1749696   Click image for larger version
ID:	1749697   Click image for larger version
ID:	1749698   Click image for larger version
Old 05-24-2012 | 07:13 PM
  #64
Hello Alex,
Is this model intended to be covered entirely with iron on film (I understand paint would be required on fiberglass parts)? I'm curious as to the impact of glassing/painting on overall weight.
Thanks!
- Steve
Old 05-25-2012 | 07:44 AM
  #65
Hi Steve,
You're right, paint is required for the cowl, canopy and spinner. The fuselage can be either film covered or glassed/painted, it's your choice. The film for the fuselage weights around 80g, glass/paint is a little heavier (~240g) so you need to be careful. You can find more details in Claude's post [link=http://www.rcuniverse.com/forum/fb.asp?m=9401044]here[/link] (post #118). I would say if you decide to go with glass/paint you need to choose the lightest balsa you can find for sheeting the fuselage.
Old 05-26-2012 | 06:43 PM
  #66
stonyZ's Avatar
hi are plans available for this plane? thanks
Old 05-26-2012 | 10:36 PM
  #67
Sorry, the model is only available as a kit.
Old 06-20-2012 | 12:46 PM
  #68
gdaddy's Avatar
Hi, really beautiful airplane!
Could you post the general dimensions of the fuselage? I'm interested in knowing how tall it is at the canopy and the width as well. Its kind of hard to tell in the pics.
Thank you!
Old 06-21-2012 | 07:13 AM
  #69
Thanks Gdaddy, here are the dimensions you asked for:
- max fuselage height in the canopy area: 340mm
- max fuselage width: 160mm
- rudder is 414mm tall
In general Radiance is a little bigger than the Integral.
Old 06-22-2012 | 07:08 AM
  #70
ORIGINAL: Alex Voicu
Hi Alex,
Did you model the entire OS 33 in Solidworks too? If so, would you be willing to share a file?
-Steve
Old 06-22-2012 | 08:22 AM
  #71
Sorry Steve, i don't have a 3D model of the OS33. I used a 1:1 scale picture from the engine manual.
Old 06-22-2012 | 09:24 AM
  #72
Hi Alex,
What are the chances that you'd offer a 'IC/wet power compatible' fuselage at some point in the future?
It seems that you did a masterful job of optimizing the structure for electric power. I suspect trying to use an engine like the OS 33 or one of the YS's would be more involved than simply confirming that it fits the cowl and then 'beefing' things up.
- Steve
Old 06-22-2012 | 09:56 AM
  #73
Hi Steve,
Maybe in the future, if the sales go well, we will be able to offer a IC power version, but at the moment it would be too expensive for us to retool for IC power, build new airframes and test them. Don't know about the OS33, but looking at other kits designed for the YS170 like the japanese Wingray, i would say the structure is at least equally strong.
Old 07-18-2012 | 03:27 AM
  #74
Hi
I see that the cowling are put on the fuse with some smal screws, is the front big enough to slide a normal outrunner in??
I lokking after a new project for next winter but dont like a cowl that are mounted like that.
So I was think maybe glue it in place as they normally do on the japaneese kits and either mount the engine from front or from the inside off the fuse.
Old 07-18-2012 | 08:29 AM
  #75
Hi Rune,
Radiance is designed for backmounted outrunner motors. The diameter of the spinner is 82mm, so i would say you can slide a regular outrunner in through the front of the cowl, but not with the X mount installed. Anyway, if you choose to glue the cowl in place, i'm not sure you will be able to access the motor screws easily.
If you are concerned about the small cowl screws, you don't have to drill them through the side of the fuselage. There is a way to hide them inside the model (drill the holes through the firewall and cowl frame).
