Skyshark Aichi (VAL) On-Line Build
If anyones interested I'm doing a full build of the Skyshark Val over
here http://www.*************.co.uk/4um/i...;threadid=5132
But I'll also post some highlites here for welcome comments
Heres the specs
1/9th Scale
Wingspan: 63 inches
Wing Area: 680 Sq. In.
Flying Weight: 5.5 to 6.5 lbs.
Engine Size: .45 to .61 2-stroke, .56 - .72 4-stroke
I'm going to fit an RCV 58-CD
Here are the superb aileron cnc parts
Heres the specs
1/9th Scale
Wingspan: 63 inches
Not had any replies, but the thread has been read, so I'll stick another picture here
This is the Centre section of the wing assembly
The parts are the best fitting of any kit (TF,GP,CG etc) that I've ever seen. The centre section is almost fully built before you apply a single drop of glue [X(]
My Feedback: (90)
ORIGINAL: grahamd1
. I have been wondering about this kit since I saw on "coming soon" pages of their site. Sure would like to see an 80" version. Maybe they will in the future.While you are at it, show us some pics of the glass and other pre-molded parts.
NY
Grahamd1; I am seriously considering the Val as my first true Warbird. I will be following your thread with great interest. Thanks for the opportunity to learn a bit before I throw my hat in the ring, so to speak.
Graham,this Looks like a fantastic kit, laser kits go together quickly and with a fixed UC this could be a good propersition for getting a war bird in the air for next spring.
Added the top sheeting on the centre section, this comprises of 4 15 1/2" 1/16" sheets joined together, I used 2 soft for the front and two hard for the rear, this way I can bend the front sheets over the ribs, with the rear hard sheets laying flat. I now need to install the "Y" lead and extension leads for the outer wing aileron servos.
grahamd1
Did you get the kit from a distributor in the UK,
or ordered it from the US ???
Nice looking Val, some time ago I was planning to scratch
build one, but voila here is a very nice kit!
Anyway Xmas is next month ! no one knows.
Cheers
Hisham
Cheers
Hisham
Hisham I got it via air-mail from Skyshark in the US, but the UK distributor should have them by end November.
Like you I want a 1/5th scale one, and what better way to get the info [:-]
Before the bottom of the centre section is sheeted, it is recommended you remove the flap push rods (this makes sence), however I was a bit worried about having to blindly align the rods back into the wing, so I added short lengths of fuel tubing. This should make it easier.
