Sig 1/6th J3 Cub
#176
It made quite a nice airplane, well done.
#178
here some shots of the wing struts. i went with the kit's plan on using screws to fasten the struts to the wing undersurface but decided it would be too tedious to use the plan's idea of using nuts and bolts to fasten the struts to the fuse so i went with clevises instead. not as scale but probably infinitely easier at the field. now i need to put some scrap balsa on the strut support wires and sand to shape. kinda burned out on sanding as it took me hours to sand the 4 spruce struts to shape.
#180
I may be able to assisst with some pics from my build, if it's OK with tubig.
I found it easier to complete the fuselage covering and finish prior to attaching the stab halves to it.
Note that you need to maintain a gap between the stab root and the fuselage side, this is scale!
