JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Attention JetCat Owners
Old 03-30-2005 | 01:45 AM
My Feedback: (8)
Default Attention JetCat Owners
When hooking up the battery to your JetCat ECU do not put a switch in series with it. The battery should be plugged in straight to the ECU with no other connections in line. There can be times when the pump can spike (for a brief second) up to and greater than 40 amps. Most switches cannot take this load and a powerfail will occur. A powerfail will shut your engine down every time. It is a failue mode that tells the ECU the aircraft has lost power. When this happens the ECU is programmed to shut down.
We found this in one aircraft at LA Jets this last weekend, and have reviewed the manual. It does not state you cannot put a switch in there, but then again it does not state that you can. All engines leaving JetCat USA from today on (03/29/05) will have an addendum in the manual stating not to install a switch in line on the battery cables. The manual will be updated immediately.
Once again, do not install a switch of any type in line on the battery wires.
If you have one installed, please remove it immediately.
Old 03-30-2005 | 05:55 AM
rcguy!'s Avatar
My Feedback: (69)
Default RE: Attention JetCat Owners
ORIGINAL: John Redman
John,
I've installed a DEANS Ultra plug between the ECU battery and the and the ECU to make swapping is out easier. Is this OK? Starts and runs fine.
Dave Rigotti
Old 03-30-2005 | 10:30 AM
mr_matt's Avatar
My Feedback: (10)
We have tested and authorize the Deans Ultra and the Multiplex power connector that comes with the turbine.
Old 09-02-2005 | 04:18 AM
john
i was just reading about the in line switch, i have a couple of p80 and a 160 i have solderd a deans plug into the line so as i dont have to keep pulling it out of the e c u . the question is i have a super nover 3000 can i charge my battery with out pulling the plug out of the ecu or will i stuff my ecu if i leave it hooked up while charging
thanks mavrick
Old 09-02-2005 | 09:34 PM
mr_matt's Avatar
My Feedback: (10)
I am not familiar with that charger, but if it has a negative pulse for the peak detector it will damage the ECU if connected while charging.
Good luck,
