Welcome to Club SAITO !
Old 01-23-2008 | 07:38 AM
  #9751
Hobbsy's Avatar
My Feedback: (102)
Default RE: Welcome to Club SAITO !
BH, look back through these pages for my break in method, it works every time and in about 40 minutes you'll have a Saito that holds compression like an ABC engine, runs smooth as silk and burns little fuel. If you can't find it I'll re-post it.
Old 01-23-2008 | 07:48 AM
  #9752
BountyHunter51's Avatar
Thanks Hobbsy, I'll do a search and see what I can find.[8D]
Cheers! BH
Old 01-23-2008 | 08:33 AM
  #9753
Could you re-post that break-in method, i've got a 180 i'm getting ready to run on a Ultra-Rc Goles 202.
Old 01-23-2008 | 09:50 AM
  #9754
blw's Avatar
blw
I found some black RTV recently. I needed that color for another project.
Old 01-23-2008 | 10:52 AM
  #9755
Hobbsy's Avatar
My Feedback: (102)
OK
10 minutes at 4,000 rpm with throttle 1/4 to 1/3 open, HS needle about 4 turns open. This is the most important part of the break in.
10 minutes at 5,000
10 minutes at 6,000
10 minutes at 7,000
Peak HS needle at absolute peak and leave there temporarily, start leaning the LS needle 1/8th turn at a time, checking the transition after every other change, at some point it will just quit when you test the transition. Re-richen the LS needle 18 to 1/4 turn. While doing this keep reducing the throttle setting as low as you can get it to idle. A good transition is far more important than the lowest idle speed.
With the 1.80 you may need to re-fuel in the middle of this, you don't with the smaller ones.
In 40 to 50 minutes you will have accomplished what many say takes 100s of gallons. This method was sanctioned by Bill Robison.
Old 01-23-2008 | 01:27 PM
  #9756
My Feedback: (8)
for a spinner nut, take the insert out of the starter, flip it over. there is a hole in the back side of the insert tht fits well on a spinner nut. i do it all the time at the field to go between spinner nuts and spinners.
jon
Old 01-23-2008 | 04:16 PM
  #9757
Black RTV is supposedly the best but i still think the fuel weakens it. I stay away from it. If anything find a product called "The Right Stuff" from permatex.
I used many Gasket making compounds on my slimline , so far The Right Stuff has been the only one to seal up good and not start spitting out the exhaust.
Avoid using anything if you can, specially if it can get inside your engine!
Old 01-23-2008 | 09:54 PM
  #9758
Thanks for the info, i'll let you know how it goes.
Old 01-23-2008 | 11:26 PM
  #9759
Hey guys, I've been noticing some bearing noise on my 82. It was my first Saito and I didn't break it in as well as I should of, but its had about five gallons of fuel through it and it's been running fine. The thing is , I removed the rear plate and filled it with MMO to let it soak. It's been soaking for about a day and oil has started to seep out around the prop shaft. Is this normal?
Old 01-24-2008 | 01:33 AM
  #9760
Similar question, how do you tell if either the front or rear bearing set needs to be replaced?
Also, I have a Saito 72. I recently took the backplate off and noticed what appears to be wear from the connecting rod rubbing against the backplate in a pattern of slightly more than a half circle. What would be the likely cause? Bent connecting rod? Worn bearing?
Old 01-24-2008 | 02:11 AM
  #9761
ORIGINAL: 1rcaddict
I wouldn't worry about it if the engine runs well. Most of my engines regardless of 2 stroke, four stroke, or brand, will seep oil if I put in a good amount and let them sit. I have also noticed that a few drops of oil grows into a quqrt or so when it leaks onto the floor.
jess
Old 01-24-2008 | 02:54 AM
  #9762
boogermancan's Avatar
the problem comes when one of the balls falls out of the race and tangles up with moving and not moveing part [sm=48_48.gif][sm=48_48.gif]
Old 01-24-2008 | 12:48 PM
  #9763
ORIGINAL: KLF1292
If you can feel any side to side motion of the front of the crankshaft, your bearings are worn. How much wear is acceptable to you is probably personal preference. If I can feel play, I think it is time to replace them. Bearings are cheap to replace, when compared to the damage that can be caused by loose metal particles finding their way into critical areas.
The swirling pattern on the front of the backplate wouldn't concern me. When you push against the spinner to use an electric starter, the crank can brush up against the backplate a little. It might happen when the engine is idling down, and acting like a brake as well. Now, if metal is actually being REMOVED from the backplate, that is a different matter.
It isn't unusual for oil to leak through your front bearing. The seals aren't 100% oil tight.
Old 01-24-2008 | 04:08 PM
  #9764
Hi guys, I'm getting ready to break in my first Saito this weekend, a Saito 100. I plan to mount it on my new Phoenix Models Extra 330S 90. I was wondering if anyone could give me some advise. Should I use the stock nylon mount that comes with the ARF, or is there a specific mount I should use for this engine? The ARF comes with a 270 deg inverted mounting possition. Should I stick with the stock mount and possition? Any help would be appreciated. Thank you!
Old 01-24-2008 | 04:27 PM
  #9765
w8ye's Avatar
My Feedback: (16)
The nylon mounts typically work very well
Old 01-24-2008 | 06:28 PM
  #9766
RPMcK's Avatar
Hi, I'm mounting a 180 in a Giant Super Sportster and I think I'm going to need to move the intake manifold a little in order to install an air cleaner. I'm wondering if I should just plan on having to install new gaskets (O rings or what ever) or would it probably not damage them. I know - crystal ball type of question. Just thought maybe someone has had experience with doing this. I'm totally new with these engines. Thanks, Ron
Old 01-24-2008 | 06:41 PM
  #9767
w8ye's Avatar
My Feedback: (16)
The seals will accept a few movements before trouble. If they still look good - re use them
Old 01-25-2008 | 02:07 PM
  #9768
Test005's Avatar
Hello
I just bought my first Saito ever. I have had many OS fourstrokes and Magnum, but never a Saito before. I bought it second hand NIB and plan to put it on a Sig Somethin' Extra airplane.
I have 14X4W prop, is this OK for break-in too?
...Yeah, it's the FA-82a model by the way
Old 01-25-2008 | 02:14 PM
  #9769
w8ye's Avatar
My Feedback: (16)
It'll be OK. Just don't let the engine run hot
A black and Gold box. Couldn't be very old. I'm thinking mine came in a white box.
Old 01-25-2008 | 03:07 PM
  #9770
Test005's Avatar
Acording to the seller: "Bought Christmas 2006 in England"
Anyways, this thing is smoking cool looking!
Old 01-25-2008 | 03:13 PM
  #9771
w8ye's Avatar
My Feedback: (16)
I was just taking notice of the box color and wondering if Saito had changed back to the old style Black/gold box they had in the 90's.
The engine is beautiful and appears to have all the latest changes. You made a good purchase.
Old 01-25-2008 | 03:20 PM
  #9772
Test005's Avatar
double post, pls remove
Old 01-25-2008 | 03:32 PM
  #9773
ORIGINAL: w8ye
Apparently so, because the two FA-125A engines I picked up on Ebay were in black and gold boxes and there was a brochure included with the instruction sheets (not small manual) that had all the engines including the FG36 gasser. The tools also included a small screwdriver.
RFan
Old 01-25-2008 | 03:48 PM
  #9774
Test005's Avatar
I have these props, which one would be prefered for break-in? (Intend to fly the 14x4w)
14x4W APC
13x8 MAS K-series
12x6 APC (Way too small I suppose as this is my prefered prop for .52 fourstrokes)
Old 01-25-2008 | 04:04 PM
  #9775
w8ye's Avatar
My Feedback: (16)
The 14-4w has less load than the 13-8
