Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Air Hogs Aero Ace!
Old 09-16-2006 | 12:21 AM
  #2976
suzonka's Avatar
My Feedback: (7)
Default RE: Air Hogs Aero Ace!
Oh That was your tooth pick aero ace, thats pretty cool ,,maybe a scewer stick glued to the leading edge of the wing would help??
Old 09-16-2006 | 12:17 PM
  #2977
Neurotex's Avatar
f u n k y~t a i l
Old 09-16-2006 | 03:13 PM
  #2978
FERNDALE AIR FORCE's Avatar
I found foam popsicle sticks at the dollar store. A new resource? Tim
Old 09-16-2006 | 04:31 PM
  #2979
suzonka's Avatar
My Feedback: (7)
ORIGINAL: Neurotex
f u n k y~t a i l
222222222222222@@@@@@@@@@22222222222222
nice neur how does itr play?
Old 09-16-2006 | 06:02 PM
  #2980
I've noticed a rattle in 2 planes recently. In both cases it is in the left motor. Sounds like a bad bearing. Are these motors reversable? Could this be a precursor to the transistor dying, more power load to keep the plane flying straight?
BTW, I popped the shell off of my gyrotor. Pic's are on the gyrotor thread. Tim
Old 09-16-2006 | 06:42 PM
  #2981
Neurotex's Avatar
ORIGINAL: suzonka
It's slowly making its way air worthy.
Never again with the sheet balsa fuselage- breaks everywhere and had to
cut some foam sheets for side reinforcement.
The time is going back home from the field everytime I bust it up from trimming.
But close... very close.
Old 09-16-2006 | 08:25 PM
  #2982
suzonka's Avatar
My Feedback: (7)
Dont give up ,I went to the meat department in my local super market they guy gave me a dozen blue and white meat trays of new foam. The blue is the same thickness as the aero ace wings
Old 09-16-2006 | 08:51 PM
  #2983
Neurotex's Avatar
Great looking jet!
When you get to test flying it, protect the nose with something like
a sponge or scrap foam. After a couple of dives testing out my foam
jet the nose ended up smooshed like an accordion.
Got the yellow winged plane flying pretty good now. Adding weight to
the nose solved the nose diving problem. Odd as that sounds, the weight
must be returing the lift back to under the wing.
Clipped the rudders and bent them in- tail now looks like a Star Wars TIE
fighter, but the plane flies and climbs nice.
Old 09-16-2006 | 10:18 PM
  #2984
After jets and tie fighters this is boring, but here is a mono mod that is controllable. I will start this by saying this plane has less than 2 hours flight time. I usually don't mod out new planes, but I wanted to try out the concept. With least chance of success. What I have is an early 06 red B channel. I removed the lower wings, glued in drink stirrers(SP?) to keep the upper wings from floating the fuse. The result is a nifty little plane. Check out the pic's, if you have a question please ask it. Tim
ID:	525282   Click image for larger version
ID:	525283   Click image for larger version
Old 09-16-2006 | 10:51 PM
  #2985
Seek and Destroy's Avatar
I need to mod mine and wait for the wind to calm down. We have had around 20mph wind the past 2 days. I haven't flown one of these in like 2 months. Mine never flew too good. It would always nose dive after a turn. I will start messing with it again. Or transfer the electronics to another plane. My best one ever, was a red B channel, and flew like a dream. It would climb at any throttle step. And would climb really high really fast. But I was flying it one day and one of the motors weant dead and weant straight down into a spiral dive. I flew it the most, and that was the one I liked to take upto 100+ feet. Oh well, I will try and get some of the video soon. I will mess with it later tonight.
Old 09-16-2006 | 11:09 PM
  #2986
rc, do you have plans for a ski mod? Where I live it's going to be hit or miss for flying outdoors. I have helis to keep me going. Where you are you could potentially fly off of ski's. Always look to the positive, you'll be happier. Tim
Old 09-16-2006 | 11:48 PM
  #2987
ORIGINAL: FERNDALE AIR FORCE
Will the ski mod make it more stabil when turning? I can usually fly outdoors, but I think were are suppose to have some big rainstorms coming here soon. What do you mean " Where you are you could potentially fly off of skis."
Old 09-17-2006 | 12:16 AM
  #2988
I mean the most evil of all weather, snow. I hate snow, sorry but there it is. But if I was forced to live where snow was going to occur, I'd put skis on my planes. Now I may be making an incorrect assumption, but I thought that all of the eastern states got snow. Yes KC MO is eastern. In my mind anything east of TX is "back East". Tim
Old 09-17-2006 | 12:36 AM
  #2989
makg's Avatar
I bet i'm the one of the farthest north AA owners in the world, i've already made skis, too
Old 09-17-2006 | 12:45 AM
  #2990
well done!!! Makg!!! I have been pondering skis for a while.
Suzonka, the mono mod I just posted, seems like you could land it with landing gear in the corrct conditions. I tend to fly over grass and land wherever I hit. Tim
Old 09-17-2006 | 02:52 AM
  #2991
new to the forum here. there is so much to read through. I have simple battery charging question though. is it ok to try and charge the plane even if it has bit of charge left in it?. or should I run it down first? and what is "cycling" the battery? Is it harmful if I accidentally tried again to charge a full battery?
Also, is there any maintenence or whatnot that can or should be done with these motors to keep them running well? This plane is just too much fun....
thanks in advance....
Old 09-17-2006 | 06:27 AM
  #2992
suzonka's Avatar
My Feedback: (7)
SOME PEOPLE CHARGE THEARS TWICE TO GET LONGER RUN TIMES, SO IT WONT HURT TO TOP YOURS OFF EVERY FLIGHT
Old 09-17-2006 | 09:01 AM
  #2993
Neurotex's Avatar
ORIGINAL: rc18t145
A couple of things you can try. If it's diving on a right turn twist the right
motor just a tad so the props thrust is away from the fuselage. If it's diving
on a left turn, do the same for the left motor.
Or you can try trimming a bit off the rudder.
Old 09-17-2006 | 11:17 AM
  #2994
ORIGINAL: doser
You don't have to worry too much about these batteries. They don't need to be fully discharged and the charger won't overcharge them. The only thing I would be careful of is not leaving one discharged very long. Lipos will not charge if the voltage drops too low. The plane cuts off at this voltage (~3V) but all batteries lose a little power just sitting on the shelf.
Chris
Old 09-17-2006 | 11:30 AM
  #2995
I tried flying in some wind and every time I turned into the wind, the plane dropped. I just couldn't get any lift. This got me thinking again. The motors point slightly down to give the plane more lift. This has a tendency to cause stalls so we bend the elevator flaps down. This causes it to dive with no power and now I see it dives in a headwind. So what if you keep the elevator tabs straight and angle the motors straight? I think it will prevent the porpoise syndrome. The only drawback I see is you won't have your failsafe dive if it gets caught by high altitude wind. Anyone care to try it?
Old 09-17-2006 | 12:58 PM
  #2996
We don't get too much snow in kansas. It does get cold sometimes though. Here is my design for landing gear. I never got to test it out because the red one died right when I was going to test it. And I couldn't get the other one to fly right.
ID:	525541   Click image for larger version
Old 09-17-2006 | 01:01 PM
  #2997
ORIGINAL: Neurotex
ORIGINAL: rc18t145
I will try those.
Old 09-17-2006 | 03:13 PM
  #2998
makg's Avatar
Well bad news for me, the red & black AA bipe I just bought two days ago just quit. The motors don't turn on, and i had just charged the battery...so my question is should I exchange it for a new bipe, or a new jet? What(if any) are the common problems w/the jet? What should i do when/if i get the jet? Thanks
Old 09-17-2006 | 03:53 PM
  #2999
Neurotex's Avatar
ORIGINAL: chris1379
If the motors are mounted as a pusher on the trailing edge then they should
point up. If the leading edge of the wing is angled properly the downward thrust
of the props onto the trailing edge will push the LE of the wing upwards, giving
the plane its lift.
I've tried everything to stop the porpoising with the best being a canard. But
then this causes new problems of its own.
The only thing to truly stop it is a third channel and elevator control.
Old 09-17-2006 | 05:17 PM
  #3000
Yes, 3000th post in this thread.
Edit: I did the move the motors like neurotex said and I used ca to stick it on there. Not the best idea but it will work for now. I will test it when the wind settles down. The wind has been very light today, so I might try tonight.
