Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Air Hogs Aero Ace!
Old 09-28-2006 | 06:25 PM
  #3176
Cobalt Saber's Avatar
Default RE: Air Hogs Aero Ace!
Can you teach me to make it??
Please....
CS
That would be a cool idea.
Old 09-28-2006 | 07:02 PM
  #3177
redmoon's Avatar
ORIGINAL: Neurotex
ORIGINAL: micro_builder
the solar cells that come out of calculators, ect, are pretty heavy and dont put out a lot of power. there are some very lightweight cells out there that put out more power, but apparently they're hard to get, expensive, and very difficult to work with (one guy said its like trying to solder a potato chip).
Thanks for the info- that's pretty much what I gathered. A project (as the electronics
progress) for the future. Wondering if the original poster who tried the calculator cells
had problems and stopped posting on the subject.
I removed a solar panel from a Solar/Hand Crank/Battery radio-light. The panel is about 5!QUOT! long by 3/4!QUOT! wide. This panel easily lights a diode (weighs only 1.25 grams) in even indoor light, so I believe that it is enough to charge a plane in flight to extend the time.
I will install it along the upper wing as an additional support. I have also added 2 additional motors to my AA so any extended time would be great.
redmoon
Old 09-28-2006 | 07:36 PM
  #3178
FERNDALE AIR FORCE's Avatar
Has ayone radius-ed a wing for a mono mod? If so how does it fly?
Dj, what's up with your light kits? Assuming that spinmaster or silverlit pushes the planes at all this christmas, sales will climb. Tim
Old 09-28-2006 | 08:33 PM
  #3179
MegaByte-2's Avatar
Djstinger
If you are using 8 cells on the Tx the tap should be in the middle. Or add 1 cell to each end. The Tx schematic posted at rcforums with SilverLit on it is wrong.
The RF output and charger uses the 9v. The 4.5v center tap is used to run the micro controller chip.
If you get the 2 extra cells on one side of the center tap the voltage is lower. On the other side its higher.
Both can be bad. To much to the controller or weird things happening from hardly ran rechargeables due to it is running on 3.75v(3 NiMH) after a full charge.
Wont take much to start dropping Vcc and its normally looking for 4.5v.
Better to keep the centertap in the middle of the 8 cells.
Tony
Old 09-28-2006 | 09:41 PM
  #3180
Redmoon. what is the output on that cell? The post on the solar cells indicated that he used the cells out of 2 calculaters from the dollar store. He the mounted them in the "windshield area". If you have a 5 x 3/4 cell where are you going to put it? I seriously believe in the creativity of our community, but the cell would need to be the main wing. And it would need to be wired to the charge port. Whatever, it is your plane, have fun. Tim
Old 09-28-2006 | 09:43 PM
  #3181
Cobalt s, What do you want to make?
Old 09-28-2006 | 10:28 PM
  #3182
ORIGINAL: rc18t145
I know how to make this ariplane that will almost float when you throw it. And has the perfect setup for electronics.
Old 09-29-2006 | 12:36 AM
  #3183
micro_builder's Avatar
i would be warry about trying to charge a lipo cell with anything other than a lipo charger - including a solar cell. the 130mah's in the AA arent that big, but they can start a fire if they're "abused."
please dont get me wrong though, i'm not trying to say flying with solar wont work. its been done a few times that i've seen, one of them was 100% solar power, no battery at all - very cool (how does unlimited flying time sound - daylight permitting, of course!). i dont know enough about electronics to say how a safe way would be to rig up the solar cell, but i do know not to mess with a lipoly cell, its not worth the risk for a few minutes more of flying time. just some food for thought
nick
Old 09-29-2006 | 08:35 AM
  #3184
Fern and anyone interested in a light kit, I was thinking about $15.00 ea. shipped or 2 fer $25.00 shipped. A friend of mine was over last night for a night flight, he has the aamod lights, my lights were twice as bright. I am working with some yellow/ orange , blue/green. The only lights that I am selling for now are the blue/green set. I have some 4v 30mAh 16,000 mcd 5mm clears that you should not look at directly, I am going to those on my T-maxx but they work on the AA. I had hooked up as a search light pointing down , it was sweat with 3 lights on at the same time.
Tony, Thank you for info I will fix it when go home for lunch. I just hooked the batteries at the 5 cell / 3 cell its been like that for 6mo. now and I have never had a problem with it all, if it ain't broke don't fix it. I will be fixing this one I hope it doesn't screw up after I split to 4 / 4.
Old 09-29-2006 | 09:33 AM
  #3185
Neurotex's Avatar
ORIGINAL: Djstinger
$15 seems like a fair price. Have any pics of the set up or a web page?
Old 09-29-2006 | 10:21 AM
  #3186
MegaByte-2's Avatar
Djstinger
Its not an instant death thing. Just good practice. Most just add both cells to one end and there are a bunch out there. Never heard of any failures of killing Tx's. But it might explain weird situations if on the low side after the cells voltage drops if the controller IC is on the low side.
Probably the reason you havent seen any ill effects is the fact that NiMH's hold voltage values well then have a sharp dropoff when getting low as opposed to alkalines waining down.
Just food for thought, not an emergency.
Tony
Old 09-29-2006 | 10:29 AM
  #3187
Mega, They are good rechargeables 2650 mAh. They last just about the same amount of time as alkaline. I am interested in what effects the change will have. I was in aatoolbax looking at your jet, way cool project.
Fern, I think I need to do your wing support mod to my mono, what do you recommend for material to use?
I will post some pictures of the lights later. Oh ya, these lights can be made to fit the jet also...
Old 09-29-2006 | 12:11 PM
  #3188
Sorry to switch a subject here, but I was unable to get a reply via PM from the mod's originator, so I'll try the open forum.
Those who have been to AA toolbox have seen the "slow turn mod." I can easily drive a soldering iron around a PCB, but I need a little clarification as to the wiring WRT what is going on UNDER the PCB. The pic shows the two diodes go through what looks to be drilled holes in the board.
On another matter, I am aware of the various throttle stick mods to increase the number of steps between low and high. Is there a way to simnply decrease the available "throttle" at the first step. My monowing modded AA still climbs a touch at low position. A hiar less would allow for level flight. It would be nice not to have to wire LEDs on them model just to decrease motor RPM.
Thanks for the help.
Ben Minor
Old 09-29-2006 | 03:49 PM
  #3189
a contact on mine seperated could someone post a pic of the rx and board (where all the contacts go)
Old 09-29-2006 | 04:42 PM
  #3190
Hello, all, I have a charging problem. It seems that my charger wire is all screwy. I think it broke in the connection thing. Now my Ace can't charge, and I can't fly. Any fixing suggetions?
Old 09-29-2006 | 04:45 PM
  #3191
monstermaker13's Avatar
i need to get another aero ace soon. i have so many free flight modles....
Old 09-29-2006 | 06:18 PM
  #3192
redmoon's Avatar
ORIGINAL: googledperson
Here is a picture of the RX
Old 09-29-2006 | 06:27 PM
  #3193
redmoon's Avatar
ORIGINAL: FERNDALE AIR FORCE
The output tested on my multi meter says 5V DC in full sun (3.75 Indoors). The panel will fit across the wing span as a addational stablizer support. The plane will easily hold the very small amount of weight. I do plan on soldering it to the charge input.
I plan to have it finished this weekend. If it goes well I let you all know.
God Speed Fliers!...God Speed.
Old 09-30-2006 | 12:14 AM
  #3194
rdy 11, I have experience this problem myself. In my case I just keep buying new planes, and therefore have new charger bases. This time I am annoyed and I am going to open the charger lead. And fix the bloody thing. I'll post the fix. Tim
Old 09-30-2006 | 02:25 AM
  #3195
suzonka's Avatar
My Feedback: (7)
sounds good ,those charge plugs are kinda week
Old 09-30-2006 | 05:39 AM
  #3196
Here is a picture of a light kit that I made for my jet. sorry for poor picture quality.
Old 09-30-2006 | 07:17 AM
  #3197
suzonka's Avatar
My Feedback: (7)
Its the light at the end of the tunnel
Old 09-30-2006 | 10:13 AM
  #3198
Neurotex's Avatar
Went to a built up wing- less chord & more length- 18"
Width of the airfoil = 13mm tapers down to 7mm. A lot more lift.
Oddly had to angle the tail boom up about 2" to push the wing.
I don't know how much advertising has to be done to generate sales
in this market but if it's like any other, it takes time, usually half the
time spent on a business.
Tony, do you still have the parts to do one more RX mod?
Old 09-30-2006 | 10:36 AM
  #3199
MegaByte-2's Avatar
Djstinger
Thanks.
I doubt you see any difference unless you have had unknown problems you cant explain.
You must recharge before the voltage drops to the critical point, whatever voltage that is. Never seen it posted.
If the IC Micro controller was TTL its voltage range is 4.75-5.25v. so......even low stock wired alkalines would be flakey.
It must be CMOS. Its low voltage threshold could be 1.8-3.0v before problems occured.
Dr.Ben
The first AA/X-Twins had those 2 diodes installed from the factory. (D7 & D8), by the gimbal on the PCB. The turning radius was stated to be abt 50'. People started disconnecting the common point and found that the turning radius was much quicker. SilverLit quit putting them in. They are still marked on the board.
Seems now people have planes that they want a slower turn and are putting them back in and a sw on the common point to activate it. Diodes are the 1N914/1N4001 signal ones, same as the Zero throttle turning mod.
Tony
Old 09-30-2006 | 05:17 PM
  #3200
Seek and Destroy's Avatar
ORIGINAL: Cobalt Saber
Please....
CS
It might be a little hard on the internet. But if you throw it very hard, it spirals. So you probably can't be on full throttle. I'll see if I can find the instructions. I could draw it, or take pics of it, but it probably wouldn't show you much. Or I could do a vid, but that would be harder.
