Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Nother 27% CA 300L Build
Old 11-02-2005 | 12:10 AM
Steve's Avatar
My Feedback: (54)
Default Nother 27% CA 300L Build
I picked up a Colombo Anderson 27% 300L on RCU this summer for $190.00. Just could not pass that up. It is one of the original kits and had the wing tube that was not cut right, but it's still an incredible kit. I'll be putting this together for the next few months. Here is a couple of pics of the first few steps.
ID:	347419   Click image for larger version
Old 11-02-2005 | 12:32 AM
rcblimppro's Avatar
Default RE: Nother 27% CA 300L Build
The CA Extras are great flying airplanes.
ID:	347425   Click image for larger version
Old 11-02-2005 | 10:38 AM
Steve's Avatar
My Feedback: (54)
rcblimppro,
Looks like pre-flight photos. How much flight time do you have on it now? How is that DA running?
Old 11-02-2005 | 10:57 AM
Chris Moon's Avatar
My Feedback: (8)
You will love it.. My 31% went together perfectly and everything aligned without any tweaking at all. Best of all, it flies great!!!
Old 11-02-2005 | 12:04 PM
v-snap's Avatar
My Feedback: (18)
What is wrong with the wing tube? Are you talking too short or the foam cores are cut wrong? Well I will tell you for the short tube I got an extra piece from Gator RC for the fuse. As for the wings, don't know if people didn't think of it or mine was the only one but they were cut upsidedown. In other words I just had to flip the cores and I had the correct taper of the top (flat) and bottom. Then I just adjusted the ply root rib for the new cut out locations and built normally from there.
Good luck it is a great flyer.
Old 11-02-2005 | 03:33 PM
Steve's Avatar
My Feedback: (54)
Scott,
The tube that gets glued into the fuse is too short. I think they want us to cut it in half and then just glue it to the outer sides. I just cut another piece and glued it to the short piece. I use it as part of a tank plate mount.
Old 11-02-2005 | 10:56 PM
Steve's Avatar
My Feedback: (54)
I know the 31%er flys great. I put two flights on mine before something went wrong. But the two flights got me hooked on these models.
I've put some extra brasing on the engine box/landing gear area while its easy to get too.
ID:	347907   Click image for larger version
Old 11-02-2005 | 11:09 PM
Steve's Avatar
My Feedback: (54)
Next is gluing in the formers and adding some 6 x 6 brases to the formers. Then adding the bottom stringers.
ID:	347916   Click image for larger version
Old 11-03-2005 | 08:29 AM
Slyder's Avatar
Old 11-03-2005 | 11:27 AM
v-snap's Avatar
My Feedback: (18)
Yea they fly great. I let a buddy of mine try the 27% and then a 34% came up for sale cheap, he bought it. I get to build it for him this winter. Should go quick that's for sure.
Old 11-03-2005 | 04:23 PM
Steve's Avatar
My Feedback: (54)
You will have to post some picks of the 34%er.
Old 11-03-2005 | 06:30 PM
Slyder's Avatar
Are the control surfaces already cut out?
Looks good Steve. Keep the pics coming.
Old 11-03-2005 | 07:33 PM
rcblimppro's Avatar
As of right now I must have about 100 flights on it. All the radio gear and engine were new with this airplane. The DA 150 is an absolute animal. While I have not put a tach on the engine it pulls the airplane vertical forever. I got a BME wood prop for break in, painted it white and have been using it ever sense. It was recently compared side by side to a Mej 32X10 and the BME is an exact copy but in wood. I am currently using penzoil air cooled oil at 60:1 and the engine loves it. The 8611 servos feel just as tight as they did on day one. I am using a Smart fly power expander and have been very happy with it. One thing I would highly recomend to anyone cuilding a CA kit is to sand the leading edges fairply sharp to aid in snapping manuvers. Mine came out nose heavy as well as a few others that I have spoken to so I took the kit cowl and made a mold from it. The Fiberglass and carbon cowls that I made for mine came out 4 oz lighter than the stock. That allowed me to run one of my Titanium Series tailgears without having to add weight in the tail. All up weight on the one pictured is 34 3/4 pounds. At the recent Southwestern IMAC regionals in Vegas I placed 5th in Advaced using this airplane.
Shawn
Old 11-03-2005 | 10:04 PM
Steve's Avatar
My Feedback: (54)
Eric,
I don't have the controle surfaces cut yet. I have to do the elevators next. The fuse is almost done.
ID:	348382   Click image for larger version
ID:	348383   Click image for larger version
Old 11-03-2005 | 10:09 PM
Steve's Avatar
My Feedback: (54)
Shawn,
Glad to hear every thing is working great. Thats got to be one FUN plane to fly. Can't wait to get this one in the air. Thanks for the specs.
Old 11-04-2005 | 06:17 PM
Steve's Avatar
My Feedback: (54)
Got the rest of the fuse cross brasing in and added the turtle deck. I used Gorilla Glue to atatch the turtle deck. It works great.
ID:	348746   Click image for larger version
Old 11-06-2005 | 12:42 AM
Steve's Avatar
My Feedback: (54)
The fuselage is almost complete. I put the hatch together and got it sanded down. I use a plane, then a sanding block.
ID:	349459   Click image for larger version
ID:	349460   Click image for larger version
Old 11-06-2005 | 01:00 AM
Steve's Avatar
My Feedback: (54)
You have to add some 8mm balsa to the rear of the cocpit area as a filler, but the instructions leave this step out. I used the tab method for ataching the hatch to the fuse.
ID:	349467   Click image for larger version
Old 11-07-2005 | 07:45 PM
Steve's Avatar
My Feedback: (54)
The hatch is atached and match up to the fuse now. I still have to add a little sheeting to the bottom stringers.
Anyone have some vidios of these models in action???
Old 11-10-2005 | 06:28 PM
Steve's Avatar
My Feedback: (54)
I got started on the elevators next. The first step is to glue the leading edge on. I use white glue for this and epoxy on the hinge surfaces. Then cap the end and cut the elevator from the stab. I used 3/8" balsa for the leading edge of the elevators and 1/4" balsa for the trailing edge of the stab. I'll do the same on the fin/rudder.
ID:	351989   Click image for larger version
ID:	351990   Click image for larger version
ID:	351991   Click image for larger version
Old 11-11-2005 | 01:44 PM
Slyder's Avatar
Looking good Steve.
One thing to watch. You might want to cut the inner corners of the elevators to get max rudder throw.
What did you use to cut the ele. stabs?
Old 11-11-2005 | 01:46 PM
Slyder's Avatar
BTW. That is my 27% in my avatar.
Old 11-11-2005 | 09:54 PM
Steve's Avatar
My Feedback: (54)
Eric,
Is that a low knife edge or a wind gust on take-off??? Looks like you did a real nice job building it too!!. I use a band saw to cut the elevators off of the stabs. Then I use a bench belt sander to true up the lines and make them strait. I will not cut the angles on the elevators until I get the rudder built and check deflection. Thanks for the heads up on that. I don't want any binding between the rudder and elevators.
Old 11-11-2005 | 10:22 PM
Slyder's Avatar
Wind gust on landing. Drug the wing tip for a foot. Thank goodness for power.
Bought it used. Wish I had the proper tools. Would like to build one myself.
Old 11-11-2005 | 10:25 PM
Steve's Avatar
My Feedback: (54)
Here is a couple more pics of my progress.
ID:	352671   Click image for larger version
ID:	352672   Click image for larger version
