Reload this Page >
Ziroli small 70" P-47
Old 02-16-2006, 06:48 PM
niraj36
Default Ziroli small 70" P-47
Hello all..
I am thinking of building the small Ziroli P-47 as my first warbird and plan built project. For those who have built one.. what weight did yours come out after glassing, paint, retracts, details etc? Is she pretty easy to fly?
Old 02-17-2006, 08:34 AM
Chad Veich
My Feedback: (60)
Default RE: Ziroli small 70" P-47
They build heavy for their size, usually in the 15-17 pound range. Don't let it scare you though, they fly just fine at that weight. If you do a search you will probably find quite a bit of info on this airplane here at RCU. Regards, Chad Veich.
Old 02-18-2006, 10:09 AM
ekir
I built my small Ziroli P-47 and used a G-38 Gas Engine, Robart Retracts, Flaps, glassed and sprayed with latex house paint. I tried to keep the weight down, but still ended up at 16.5 pounds. It flies very well at this weight. Lands like a dream. I like to bring it in for a two wheel landing.
Ed
Old 02-23-2006, 08:43 PM
Chilipecker
My Feedback: (37)
Chilipecker's Avatar
Found them...
Old 02-27-2006, 01:09 PM
CUB1
CUB1's Avatar
Hi Guys,
I'm glad I saw this post on the weight of this plane, I was planing on using a Sachs 2.0 (35cc)engine on Ignition. I also have a BME 44 (2.7cc) engine that I could use. Which one do you think I should go with?
TIA,
John
Old 02-27-2006, 03:03 PM
Chad Veich
My Feedback: (60)
John, the one I built was overpowered with an OS 1.60 but did require some nose weight. I don't recall how much exactly, I think between 10 or 12 oz. The Sachs would be more than enough power and would probably be heavy enough to alleviate any tail heaviness. The BME would make it a rocket ship!
Old 02-27-2006, 04:53 PM
CUB1
CUB1's Avatar
Chad,
Thanks for getting back to me so quickly......I will go with the Sachs 2.0
I like flying my Warbirds in the scale manner, with a little power to spare.
Thanks again,
Old 02-27-2006, 05:04 PM
samparfitt
My Feedback: (43)
If Nick recommends a G-38 then it's gotta' be the right size engine for this plane!
http://www.ziroliplans.com/cat_frameset.html
ID:	416894   Click image for larger version
Old 02-27-2006, 05:46 PM
Chilipecker
My Feedback: (37)
I would like to try one.... If anybody has a set of plans, a cowl, or any other parts sitting around that is not going to make it to the building board, please let me know how much you need for what you've got.
THANKS!
You guys are GREAT! I have everything now except for plans. If you have an old used set, even if you have cut them up, it would work for me....
Old 02-13-2007, 04:57 PM
niraj36
Does anyone have an opionion on using an OS BGX 3500, Supertiger 2300 or 3250 engine with the Ziroli 70" P-47?
Old 02-13-2007, 05:42 PM
Chad Veich
My Feedback: (60)
I've seen it flown with everything from a Webra 1.20 (roughly the same as the 2300) all the way up to a Webra Bully, which is about the same cubic inches as the BGX if I'm not mistaken. All of them worked fine. If it were mine I'd probably go with something at least 1.5 cubes or bigger just because you will need the nose weight up front and the airframe is plenty sturdy to handle lots of horsepower.
Old 02-14-2007, 09:54 AM
niraj36
Thanks for the feedback. Do you think the OS 1.60FX would be sufficient for an 18lb plane? Here are the specs on that engine:
SPECS: Displacement: 26.23cc (1.60 cu in)
RPM range: 1,800 - 10,000
Bore: 33.6mm (1.32")
Stroke: 29.6mm (1.17")
Weight: 930g (32.8oz)
Horsepower: 3.7 BHP at 9,000 RPM
I am also considering the DPM Blue Head 1.8
Old 02-14-2007, 10:40 AM
Chad Veich
My Feedback: (60)
ORIGINAL: niraj36
I think the 1.60 is plenty of power. I built one for a customer that came in around 17 pounds, maybe a bit more, and flew just fine with an OS 1.60FX. Down here in Phoenix it was a rocket ship. It also flew up in Denver with the 1.60 and still had plenty of power, although you could certainly see the difference the altitude makes.
Old 02-16-2007, 03:23 PM
niraj36
Thanks all for your feedback!
Old 08-07-2007, 09:00 PM
SIX GUNS
SIX GUNS's Avatar
CAN ANYONE GIVE ME SOME INFO ON BUILDING THIS PLANE WHAT ARE THE HARD PARTS
TO PUTTING IT TOGETHER OR DO'S AND DONT'S
