 Hangar-9 Sopwith Camel Build Thread >
Old 02-01-2016 | 05:27 PM
  #1401
WW1 Flying Ace's Avatar
So, I cut the wing lengthwise at the aileron cutout, cut off the leading edge at the ribs, removed all the shear webs and nailed the whole wing flat to the board. Replaced the LE with laminated 1/4" stock, added LE gussets on each rib, replaced the shear webs, added a second set to the front of the spars, and re-glued the trailing section. Sanded the top smooth, unpinned it from the board and - and it's still bowed. Less, but still there. Next up - surgical removal and replacement of the main spars by running the wing down lengthwise down the table saw. Here it is while still pinned down.
Old 03-23-2016 | 08:21 AM
  #1402
Ran all three panels (upper and two lowers) through the table saw as described and replaced all the main spars. Worked ok. Covered with Koverall, and am adding the rib tapes now. They are pencil marked with the stitch points, torn from Solartex and ironed on. Will add blobs of RC-56 when complete, then nitrate dope.
Old 03-23-2016 | 09:37 AM
  #1403
Mustang Fever's Avatar
I think if I ever had to do that much to mine, I'd chuck it and build a BUSA one.
Old 03-23-2016 | 09:41 AM
  #1404
Well, all the assemblage is done for you, and I didn't like the monokote covering - which was the wrong colors (gray on the bottom) anyway. My only concern will be how heavy this comes out on this sized airframe. But, for me, having all the strut and LG fittings built and fitted, the control runs, etc will save a lot of time. I plan on adding some scale detail to the cockpit area and hatch too.
Old 03-24-2016 | 03:05 PM
  #1405
Ace,
That is very cool! Great work.
Old 07-31-2023 | 09:15 AM
  #1406
affas's Avatar
Old 01-27-2025 | 08:18 AM
  #1407
This project languished in the shop for 9 years! I painted it recently and managed *not* to lose all the parts (despite moving our home twice, since) and am now - on the 9 year anniversary - assembling it. The E-Flight 60 motor will have battery (or 2) in front of the firewall. Figuring out the geometry on that now - first effort would not fit behind the dummy engine.
Old 03-29-2025 | 09:29 AM
  #1408
Finished product.
Old 06-04-2025 | 10:35 AM
  #1409
Default Looks good
Looks really good
