View Poll Results: A poll
O.S. Max .40 LA $59.99 at Tower Hobbies
11.58%
Super Tigre GS-40 $49.99 at Tower Hobbies
42.11%
GMS .40 ABC BB $59.99 at Tower Hobbies
2.11%
Thunder Tiger GP-42 ABC $59.99 at Tower Hobbies
18.95%
SK .50A $59.99 at Kangke USA
13.68%
JBA .39AR $59.99 at Kangke USA
3.16%
Magnum XLS-46A $59.99 at Hobby People
8.42%
Voters: 95. You may not vote on this poll
Best Choice - Sub $60 glow engine
Old 01-04-2007 | 02:32 AM
bigedmustafa's Avatar
Default Best Choice - Sub $60 glow engine
Which 2-stroke glow engine would you buy for less than $60 and why would you chose that particular one over the others?
Old 01-04-2007 | 03:04 AM
Banned
Default RE: Best Choice - Sub $60 glow engine
Well it depends on what your definition of "best" is.
If you're looking for something that's powerful then your going to have to consider the SK50A, GMS40 or ST40 because these are all good, strong BB engines.
However, if you're looking for a great, ultra-reliable, zero-maintenance engine for a trainer or other application where simplicity, ease of use, low weight and flexibility is more important then the TT42GP is a winner and the OS40LA is not far behind (but way-down on power).
I can't comment on the JBA .39AR because I've not had one.
Old 01-04-2007 | 03:05 AM
Flyboy Dave's Avatar
My Feedback: (21)
I voted for the 40 Super Tiger. It's a ringed engine, and runs like a top. They are really
well built and surprisingly powerful too....perfect for all trainers and 40-46 size planes. It is
doubtful that you could ever wear one out.
FBD.
Old 01-04-2007 | 10:23 AM
If serious power is wanted for under 60$ nothing beats the ASP, SC or Magnum 52 xls (they`re all the same engine) It can be had for 55$ at the right place. If you get it make sure to set the lowend needle at only 0.5 turns out from closed or the engine will not run properly. Let me add that I absolutely love mine even though I had to replace the front bearing after not too many gallons, no biggie
Old 01-04-2007 | 12:03 PM
How can a person respond without knowing how the engine will be used? Both the type of airplane and the experience of the modeler. The recommendation should change significantly depending on those two factors.
Old 01-04-2007 | 12:16 PM
I like the Super Tiger because it's cheaper and powerful.
Old 01-04-2007 | 12:25 PM
Assuming he ment 40-53 size engines there`s not that many to choose from (for 60$) and I think most have been mentioned above. If smaller engines is ment, then I guess there are plenty more to consider. It is mostly the choice of propeller that is determined by what kind of plane the engine is mounted on, not the engine itself. Remember we`re not talking Jett`s or Nelson`s for speed planes here
Old 01-04-2007 | 02:01 PM
Turk1's Avatar
Selam Mustafa Bey,
My choice is SK 50.Double B.bearing,real Chrome ABC,torquer,cheap parts.Unbeatable pricing.
Old 01-04-2007 | 02:05 PM
OK, for those wanting more specifics, it's for an experienced modeller (but not an expert). It will be used on a .40-sized sport plane (perhaps a Big Stik .40 or a Tiger 2) and it will most likely use a 10x6 or 11x6 prop depending on which is more suitable for the engine selected.
Asmund - I haven't found a reliable source for Magnum/SC/ASP engines in the .40 to .52 size range for less than $79.99 plus S&H. Any idea where they can be found for less?
Old 01-04-2007 | 02:56 PM
http://www.peakmodel.com/index.php?m...roducts_id=214
It seems they are out of the 52 at this time but the 46 should be close in power. However the 52 is more powerful in the same package and weight. Check in a little later on to see if they are in stock again. My 52 xls outperforms my friends 61 fx by far, so it has some serious power for it`s size
Old 01-04-2007 | 03:51 PM
Banned
Peak have replaced the Sany/ASP 52 with the 53 and it looks as if the new one is a *dog*.
A friend got two of these (they arrived yesterday) and they have virtually *no* compression and zero pinch (yes, they're ABC).
They barely put out as much power as a standard TT46Pro, pulling only 12,200RPMs on a 12x4 after break-in.
The 52 may have been a rocket (I've got two and they have a *lot* of pinch) but itseems that with the 53 they have bored out the cylinder to get more displacement but forgotten to make the piston correspondingly larger in diameter ;-)
Old 01-04-2007 | 04:14 PM
What??? they had a 53 some years ago, it had a cylindrical head and case and indeed it was a dog ( I had it) Is this a new 53 with the square head and case?? I didn`t see it in the Peak site. My 52 xls spins the 12.25-3.75 APC at 13700 rpm, and the 12-4 APC at 14100 rpm, ok I use the Tower muffler and have removed a headshim plus some minor sleevework, but I mean to remember it will swind that 12.25 prop about 12800-13000 rpm stock. A friend have just bought a new 52 xls (bone stock), so I will tach it as soon as we have some daylight again up here.
Old 01-04-2007 | 05:03 PM
Well, it looks like I'm on the wrong side of the globe for doing business with Peak Model. Their pricing for Sanye (Magnum, ASP) engines is terrific, but having them shipped from New Zealand to Nebraska is cost prohibitive. The Sanye .46A 2-stroke would be a bargain at $56.20, but I'd have to pay an additional $28.76 for shipping and handling. All of the engines I listed as poll choices could be delivered to my house for well under $10 s&h. I don't know of a source for Magnum/ASP/Sanye engines here in North America that could match the sub $60 pricing that Peak Model offers.
Old 01-05-2007 | 01:32 AM
Banned
ORIGINAL: asmund
Maybe they're making those 53s again then.
This one has a round head and the carby seems smaller than the one on my 52s.
The prop hub is also a slightly unusual shape.
Old 01-05-2007 | 04:00 AM
My Feedback: (14)
ORIGINAL: XJet
ORIGINAL: asmund
Thanks for the warning. Another good thing bites the dust.
Ed Cregger
Old 01-05-2007 | 07:47 AM
speedster 1919's Avatar
Well they did have alot of problems from the 52 (magnum). This seams all about price ($60) Biggest bang for the buck is the SK50 , Don't even think about OSLA or TTGP And if it is totally price the ST40 is the long term investment bargin at $10 less.
Old 01-05-2007 | 09:16 AM
Hobbsy's Avatar
My Feedback: (102)
I voted for the ST .40, the LA .46 would be an excellent choice also at only 8 bucks above the poll.
The ultimate choice might be the SuperTigre 45 at $4.99 over the poll price.
http://www2.towerhobbies.com/cgi-bin...p?&I=LXFV71&P=
Old 01-05-2007 | 09:17 PM
Banned
I have had the OS 40la engine for quite a while and have had no maintenance issues. If you want a reliable engine get this, but If you want a powerful engine I would go for the Magnum .52
Tony
Old 01-05-2007 | 10:36 PM
If you want a nice light weight and extremely reliable bushing engine, go for the TT 42.
If you want a fairly powerful ball bearing engine go for the Super Tigre 40
Old 01-05-2007 | 10:53 PM
Banned
I second the TT42GP for a good bushed sport engine. I've got one on the club's trainer and it's been through hell -- yet still puts out far more power than an LA40.
This engine has been over-used and well-abused, yet it keeps on ticking over like a well-oiled machine. It was siezed when I tried some 20% nitro fuel in it -- but suffered no apparent long-term damage. It has been driven into the ground half a dozen times but still starts immediately, has a throttle response that puts many far more expensive twin-needle engine4s to shame, and is just a lovely little engine.
It's also quite light for its power output -- if that's an issue.
Old 01-06-2007 | 08:28 PM
AMB
Having many engine in the 40 thu 53 range (many more 2 and 4 strk thru 1.2)) the ST 40 still gets my vote ringed steel liner $50
it had a very short life as glow and wears a davis diesel head have never had a carb issue sort of a super timex
cheap and works well martin
forgot has the economy muffler too conventional not that hugh garbage can that either siezes or falls off and looks like h##ll
Old 01-07-2007 | 11:30 PM
Almost as if on cue, the nice folks at Global Hobby are having a sale on Magnum engines, from now through April 1, 2007. The Magnum XLS-46A is on sale for $59.99, so I have added it to the poll choices.
Old 01-08-2007 | 08:41 AM
oceansfiftyseven's Avatar
Checked this morning, the magnum .46 at hobby people is $79.99. Not $59.99.
Old 01-08-2007 | 01:55 PM
Global and Hobby People both have the following prices for Magnum engines advertised in the March 2007 issue of Model Airplane News:
$59.99 - XLS-46A 2-stroke
$89.99 - XLS-61A 2-stroke
$119.99 - XLS-91A 2-stroke
$119.99 - XL-52RFS 4-stroke
$129.99 - XL-70RFS 4-stroke
$149.99 - XL-91RFS 4-stroke
The Global Hobby add, which encourages you to order from your LHS, is on page 1 right inside the cover. The Hobby People ad with the Magnum engine sale prices runs from pages 76 through 79.
I would guess that Hobby People hasn't updated its website pricing yet because they don't expect the ad to be in wide circulation for another week or two.
Old 01-08-2007 | 08:05 PM
Those are good deals. I just got my Jan 07 issue of Model Aviation and the Hobby People's ad still has the high prices. I sure hope they update thier website soon. Thanks
