3MM TOC-53 Gas Engine
TOC-53
Displacement 53cc
Bore 44mm
Stroke 35mm/
RPM Range 1200-7800 RPM
Horsepower 5.5 HP
Weight 1880g all up
Fuel/Ratio Premium Gas mixed 40:1~50:1
Piston Rod 2 Needle Bearings
Crankshaft 3 Ball Bearings(nsk)
Ignition 4.8~6 Volt- Electronic
Prop Size 2 blade 22x8, 22 x 10 ,23x8 3
www.3mmodel.com.tw/
Displacement 53cc
Bore 44mm
Stroke 35mm/
Horsepower 5.5 HP
Weight 1880g all up
www.3mmodel.com.tw/
My Feedback: (18)
IN
I have a few arriving today to test. It looks like a good engine that will be good for the intermediate flyer, possibly even more if I can get some good cannister setups.
What is good is the cost. I will be selling them for 420.00 with a standard muffler, now that can't be beat if we get a constant supply.
Parts and supplies will be available from us also. I hope to have things up and running by the next month with these.
My Feedback: (18)
IN
Just unpacked a couple of these and I am pleased so far. The mufflers are a little crude but I am getting in touch with bisson for some of theirs.
I will run them in a couple of days for prelims and then flight reports. I will be flying two, one in a CA 27% extra and one in an older Wild Hare extra. This should give me some good test runs.
I will have my site up by the end of the month for everything else, if you have any questions e-mail me or pm me.
Scott
Scott
My Feedback: (18)
IN
I have started a new post for the upcoming numbers and talk. We'll leave G.M. out of this as I think he forgot where TOC, AM, SD and whoever else they are came from...
Vsnap, are you going to be the authorized dealer in the States? I've looked at the videos and they seem to be OK engines and am interested in your posts. I wonder how smooth and whether or not the transition is as good as what the videos suggest.
Mike
Mike
My Feedback: (18)
IN
As of right now I am the only importer trying to set-up support for this engine that I know of, I have worked on the sole import also. I have the engines in stock for delivery and I am setting up a new location for when the new line of arf airplanes arrive. We have had great results so far and look foward to getting more of these engines out to the flying fields. All the engines have started easy and run great out of the box, one gentlemen has tested it with up to a 24-8 prop and still got 6400 RPMs out of it. 7000rpms on a 22-10 with stock muffler. Transitions are good, the carb is a check valve model so it won't draw from the chamber in the idle position. This will help with a good solid idle setting and provide for a smoother transition in the mid-range.
We like em and are flying them now, we will have a few of them flying in IMAC this summer and I have high interest from the 3-D guys due to the low cost and availability.
Scott
Scott
http://www.3mmengine.com/, a new website is now available for information regarding this engine. We welcome your input and recomendation. This engine is still available through your favorite local or Internet hobby shop.
Peace,
Steven Chao,
Cermark
Peace,
Steven Chao,
Cermark
ORIGINAL: rctom
I have some in stock. $100.
TF
ORIGINAL: WILDGAS
Where can I find a Pitts Inverted Muffler W/smoke by this engine?
TF
Could you send me the picture, please? How can I buy this muffler?
ORIGINAL: rctom
Please call me at 817-430-0107.
Tom Fawcett
Wild Hare Hobbies, Inc.
Tom Fawcett
DE
DawghouseRc is a great shop to buy from!! The owner, Scott is very knowledgeable and friendly. Bought my Yak 55sp from him with the 3MM Toc engine and all of the other stuff that is nede with the plane. Fast with delivery and trusting! Look at his website dawghouserc.netHe rocks!!
I have to give kudos to the TOC 53. A friend of mine has one in his Aeroworks Pitts Python. Man what a match made in heaven. He had trouble with it at first until he realized that the carb was installed upside down. After that not so much as a cough.
I made him a vinyl graphic to go on his cowl, sorry just had to show it off. And yes that is his LS3 vette in the background.
