Reload this Page >
Skybolt hangar and clubhouse
Old 06-18-2007, 08:36 PM
biplanemurphy
biplanemurphy's Avatar
Default Skybolt hangar and clubhouse
Share your Skybolt photos and discuss flight performance . Don't forget performance enhancing modifications.
Mine weighs about 11 lbs. Has smoke system. O.S. 120FS surpassIII W/pump. 5" wheels (no wheel liederhosen)
standard Hitec servos. 14x10 master airscrew "scimitar" prop. Fully sheeted wings. du-bro remote fuelng valves for glow and smoke.
Push-pull switches. Air-alert warnng beacon. 14 oz. fuel tank. 8 oz. smoke oil tank.
2- 1650mah ni-mh 6 volt batteries for reciever and smoke system.
Covered in Monocote.
Cowl and struts primered, painted with lustrecote, painted with finishng epoxy for fuel proofing.
Usng 20% nitro fuel.
Using "Super-Dri" aviation smoke oil.
Murphy..................[8D]
P.S. here's mine.
ID:	706707   Click image for larger version
ID:	706708   Click image for larger version
ID:	706709   Click image for larger version
ID:	706710   Click image for larger version
ID:	706711   Click image for larger version
ID:	706712   Click image for larger version
ID:	706713   Click image for larger version
Old 06-18-2007, 09:08 PM
ChrisMH
ChrisMH's Avatar
Default RE: Skybolt hangar and clubhouse
I'll add mine
11 lbs, Saito 1.20, Covered in Koverall and dope.
Edit: 10lbs 6oz after installing a hatch and moving my rx battery forward.
ID:	706724   Click image for larger version
ID:	706725   Click image for larger version
ID:	706726   Click image for larger version
ID:	706727   Click image for larger version
ID:	706728   Click image for larger version
ID:	706729   Click image for larger version
ID:	706730   Click image for larger version
Old 06-18-2007, 09:16 PM
biplanemurphy
Sweet plane Chris........I was hoping to see yours here.
Hopefully we can get Minnflyer (supreme commander of all things Skybolt) to post some pics of his (past and present).
Keep em coming guys.[8D] Tell us how she flies too.
Mine flies like it's on rails. "crosswind? What crosswind?"
Murphy....
Old 06-18-2007, 09:32 PM
biplanemurphy
So .....here's a Skybolt story......About the 5th flight, I was starting to feel real comfortable and flew a little too long.....
On approach I ran out of fuel and barely made it over the trees at end of runway. Stalled so pointed her down and recovered. Made it to 4 feet above the deck and she stalled again. dropped 4 feet straight down like an elevator. Landed on all three wheels!!
But splayed that soft aluminum gear. No real damage. Bent it back and flew her again after I stopped shaking.
Spent over a year slowly building this one, so you can imagine how happy I was to keep her in one piece!!
Murphy........
Old 06-18-2007, 10:15 PM
biplanemurphy
Hey guys.....I have a smoke system question?
I have a sullivan Skywriter and used the black hose for the hook up to the nipple on my muffler. It melts a hole through it every
3 flights. Any hose/line that is really heat resistant. my four-stroke muffler gets real hot it appears. Makes great smoke, but melts the smoke oil line.
Murphy........
Old 06-18-2007, 10:24 PM
MinnFlyer
MinnFlyer's Avatar
What smoke oil are you using?
Old 06-18-2007, 10:40 PM
biplanemurphy
Minnflyer.......Super-dri aviation smoke oil. My O.S. 120 w/pump had a screw where the exaust pressure nipple would be.
So I installed a pressure nipple and feed the oil in at that point.
Murphy......
P.S. I'm considering soldering some copper tubing to nipple and extending the mounting point for black tubing about 3".
Maybe coil the tubing around exaust header then a long extension 4-5" out to plug black tubing into.
Do you think a preheater coil would make it smoke even better? It already smokes pretty darn good now.
Thanks for any help/ideas .
Old 06-19-2007, 06:58 AM
hrrcflyer
Here are a few pictures of the one I had. It suffered an untimely death. [:@]
Fly safe and have fun!!
David
ID:	707003   Click image for larger version
ID:	707004   Click image for larger version
ID:	707005   Click image for larger version
ID:	707006   Click image for larger version
Old 06-19-2007, 07:31 AM
Gringo Flyer
My Feedback: (18)
Gringo Flyer's Avatar
ORIGINAL: biplanemurphy
That seems pretty heavy. I knew skybolts tended to build heavy but I didnt realize they were that heavy.
Old 06-19-2007, 11:03 AM
Deadeye
Deadeye's Avatar
Here's mine. A tad over 9 pounds, with lightening methods employed to reduce tail weight. Magnum 120, 15X8 MAS Classic. Fast freaking plane for a bipe! Pilot is 'Stewey' of Family Guy fame. Over a hundred flights on it now.
ID:	707137   Click image for larger version
ID:	707138   Click image for larger version
ID:	707139   Click image for larger version
Old 06-19-2007, 01:02 PM
biplanemurphy
Beautiful planes guys..........I thinnk mine is heavy due to the massive amounts of glue and epoxy I used. Added extra wood.
smoke system. and OS 120 four stroke weighs 2 lbs all by itself.
Murphy........
Old 06-19-2007, 06:37 PM
WYDAH
Hi,
Here's a few of my Skybolt. Weighing in at 10.5lbs. Has a GMS .76 (yes, 2 stroke) swings 12x6 APC. No smoke. Completed May 2003. Great flying plane.
ID:	707349   Click image for larger version
ID:	707350   Click image for larger version
Old 06-19-2007, 10:04 PM
micagreenmachin
Ok, here's what it USED to look like... Don't worry, it's still in one piece. I flew it SO MUCH I wore out the covering and am refinishing it right now. New pics soon...
ID:	707434   Click image for larger version
ID:	707435   Click image for larger version
Old 06-19-2007, 10:06 PM
tukkus
I think I have the heaviest GP Skybolt at 12lbs dry, it had an OS 91 on it but it wasn't enough power so I'm going to put a YS 120 on it and see how it goes. If the 120 isn't enough I also have a YS 140L that I can try too.
I'll get some pictures of it this weekend.
I also have a Sig Skybolt that needs some repair but that will most likely be a winter project.
Old 06-19-2007, 10:27 PM
biplanemurphy
micagreenmachin.............super nice covering job!! You must have had hundreds of flights to wear it out.[8D] How's that saito work for it? What size? How does she fly etc...
tukkus..12 lbs.[X(] with a 91 even. do you have smoke onboard? You must have used even more epoxy than I did !!
Murphy..........
Old 06-20-2007, 05:44 AM
telejojo
WYDAH,did you put the black on the wings first or yellow? I'm thinking of recovering my DP Ultimate.All of the Skybolts in this thread look great.
Old 06-20-2007, 09:35 AM
micagreenmachin
Murphy..........
She flys awesome! She weighs 8.5-9 lbs and performs well on a Saito 100. She'll weigh a little more after I'm done re-covering her since she's getting a smoke system! Some fuel/oil worked its way under the covering on the belly and on the bottom of the lower wing and I wound up replacing a lot of soaked wood. She'll be better than new when I'm done with her.
Thanks!
-t
Old 06-20-2007, 09:39 PM
WYDAH
Hi Telejojo,
I first covered it with the yellow (Ultracote), and then put on the black sunburst pattern using low heat to keep the bubbles to a minimum. The checkerboard on the bottom of the wings and the rudder are pre-printed black/yellow Ultracote that Horizon Hobbies sells. I think you can even buy it with different size squares now, 1/2", 1" and even 2" squares.
ID:	707971   Click image for larger version
Old 06-20-2007, 10:15 PM
biplanemurphy
WYDAH..........I use that same stand to build/repair etc. in !!!!
Thanks for all the good photos and tips etc.. guys.
Murphy........
Old 06-20-2007, 10:34 PM
Mods-R-Me
Mods-R-Me's Avatar
It makes an improvement on my Skybolt. Here's how I did it.
ID:	708017   Click image for larger version
ID:	708018   Click image for larger version
ID:	708019   Click image for larger version
ID:	708020   Click image for larger version
Old 06-20-2007, 10:40 PM
Mods-R-Me
Mods-R-Me's Avatar
Here's a few pics of mine. I made a double cowl mod to fit the pitts muffler and a smoke system. Also fitted external fill valves for the smoke and glow tank.
Mods
ID:	708024   Click image for larger version
ID:	708025   Click image for larger version
ID:	708026   Click image for larger version
ID:	708027   Click image for larger version
ID:	708028   Click image for larger version
Old 06-20-2007, 10:48 PM
biplanemurphy
Hi Mods........Your thread and my building mentor as well, both inspired me to maybe give the copper tubing a try.
I'm sick of melted smoke oil tubing.
Thanks.........Murphy.......
P.S. Love the "JOWL COWL"!!!!!!
Old 06-21-2007, 07:04 AM
MinnFlyer
MinnFlyer's Avatar
Hey Murph, try using regular glow fuel tubing. I've been soaking some in Super-Dri for over two years and it's still good.
Old 06-21-2007, 10:57 AM
biplanemurphy
Minnflyer........I had that thought too. But unexplicably the heat from muffler melted it too. This makes no sense because the pressure nipple I installed is in the pretapped hole the non-pumped O.S.120 4-s uses.
I'm still running the engine a bit rich. Run 1 3/4 gallons of 20% through it so far.
Thanks for help...........Murphy........
Old 06-21-2007, 11:59 AM
spanishflyer
Hello Everybody:
Here is mine:
It has an Ys-110 and it´s plenty of power, but the plane in fact is heavy, I didn´t any lightening holes in tail and I had to add 150 gr lead in the nose... That was after the first flight, CG was wrong calculated and the plane was almost crazy but with some luck I landed without problem.
I have few flights with it, but except of weight it flyes very nice, I need some time with it to try some aerobatics...
I made some changes:
the original wing struts didin´t like to me so I decided to glue two plywood pieces to original ribs an fix the strut with two screws.
I use a pull-pull system in rudder, and also for the Katoh part that moves the split elevator.
In photos you can see that changes. I hope you like them.
Thanks.
ID:	708254   Click image for larger version
ID:	708255   Click image for larger version
ID:	708256   Click image for larger version
ID:	708257   Click image for larger version
ID:	708258   Click image for larger version
ID:	708259   Click image for larger version
