ESC for turret traverse
Old 07-23-2007 | 01:43 AM
Perry S.'s Avatar
Default ESC for turret traverse
Anyone know of a good small esc I can use to control the traversse function on my tansmitter? Low amperage.
Old 07-23-2007 | 04:53 AM
Default RE: ESC for turret traverse
Perry:
You want a reversable, so one of the aircraft ones is out. Robotics suppliers usually has cheap good ones for the antweight microbots:
Robot Power's Scorpion Mini is discontinued - was $30 (replacement Mini-2 under test)
- http://www.robotpower.com/ -
SozBots SOZDSCR2.3-X is discontinued - was $58 (could be snapped to yield 2x controllers at $29 each)
- http://www.robotcombat.com/marketplace_soz.html
Barello doesn't make one under $50, and neither does dimension Engineering
Duratrax has the Sprint at $30, and is available - http://www2.towerhobbies.com/cgi-bin...?&I=LXAMN7&P=7
HiTec has the EZXR-2 at $35, its also available - http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDEM6
Then there is used ones on eBay, just make sure its usable with your radio.
I thought there was a way to hook up a servo controller board... like pull the casing, and where the board is wired to the motor, replace those leads to the servo's motor with the one to your traverse motor. Anyone done that? Got a link?
A 3-way (on-off-on) switch beside a servo should be enough... long as the voltage is right going to the traverse motor. Dead simple, cheap too.
Old 07-23-2007 | 07:15 AM
ArmChairGeneral's Avatar
You can take the stop out of a servo, it will rotate 360 degrees and has proportional speed.
Old 07-23-2007 | 09:46 AM
Here's a link for modifying a servo for continuous rotation
http://www.acroname.com/robotics/inf...ontinuous.html
Old 07-23-2007 | 02:57 PM
Perry S.'s Avatar
Thanks all for the responses, especially all the info WhiteWolf.
I could convert a servo but the HL one is much lower profile and is already installed. The Tamiya traverse mech came with a 3 position reversable switch for a servo but I need finer resolution for targeting.
I'll try to pick up one of the above ESC's
Thanks again,
Perry
Old 07-23-2007 | 04:11 PM
If you have a dead/twitchy servo from other projects, grab the electronics from it and use it to drive the HL motor. As long as the servo had a comparable size motor, it will be fine.
D.
Old 07-23-2007 | 06:21 PM
Perry S.'s Avatar
Darkith, that's a great idea, I have a few spares. Might just do that.
Old 07-23-2007 | 09:16 PM
Perry S.'s Avatar
OK, I reworked the servo board and it works great! I have to keep the pot on there don't I. It would be convenient to cut it off.
Old 07-23-2007 | 09:57 PM
There almost no end to the usefulness of a servo, I used one once to power a minisub, it gave proportional forward and reverse.
Old 07-23-2007 | 11:47 PM
Perry S.'s Avatar
So, I am done with this. I took an old JR servo I had and pulled the elec's out. I soldered on a connector for the output and mounted the board in the base of the servo case. This will allow me to use double stick foam tape for mounting. Mounted the pot on the the board with 2x tape.
I tried this out and it is awesome. regular HL traverse speeds at full stick and since it is proportional I can move the turret extremely slow with precise adjustments.
Thanks again for the sugestion Darkith
ID:	728983   Click image for larger version
Old 07-24-2007 | 07:25 AM
Yup, you can replace the pot with two appropriate resistors to make things smaller. Measure the value from the wiper to each end, and sub in a match. The values should be equal, and probably around 2.5k (for a 5k pot), so a pair of 2.2k or 3k resistors will suffice.
If the match isn't quite perfect, a little trim will fix it.
They're not carrying any current, so 1/4 watt will do.
D.
Old 07-24-2007 | 08:24 PM
Guys, I suggested that reworked servo guts...
Ah, c'est la vie...
Old 07-24-2007 | 08:43 PM
Perry S.'s Avatar
my mistake. now you have the link to your thread
