HL Tiger 360+ degree rotation turret
BC, CANADA
Follow up my idea of using twist-free phone adapter to make the turret rotate in circles. Here is what I did on the HL Tiger 1.
Material used: Twist-free phone adapter, phone socket (from an old PC fax modem), phone jack with cord, floppy drive cover from a PC case.
Thanks to Pwrwest for the idea of paper pattern to make the gear ring tab-free, and also his "easy internal antenna" (I used 9 feet Cat.5 network cable wrapped around a hot melt glue stick).
I have to relocate the controller board and the smoke unit switch, resolder and lengthen the wire from motor.. so on to the controller board in order to accommodate the adapter.
The socket from the turret would snap in to the adapter when put the turret on.
I put the finished Tiger on YouTube.
[link]http://www.youtube.com/watch?v=qd1OQF_ghlg[/link]
I also used some fishing thread and heat shrink tube to make the machine gun, the fishing thread was folded several sections and wrapped by the tube. (do not have optical fiber or rod, but works similar).
This Tiger 1 is also powered by a 7.4V 2250maH Li-Po battery.
P.S. take the battery off before moving the electronics around, I learned a lesson. I will post whether it is possible to fix the smoked controller board.
Edited: The first twist-free adapter there is too tall and the turret cannot be risen to its highest position. Rush to the store and get another one, this adapter uses a cable instead of a solid plug. This one works very well now.
Cool idea! Why not mount the rotating jack next to the terminal block in the upper hull? Using sheet styrene or cutting that one up you can make its bracket much smaller.
CA
ORIGINAL: patpatballball8888
Awesome and great to see some new innovation on the forum, thanks for sharing!!!
The Blitz[sm=shades_smile.gif]
Things like this really should be stickied.
Unlikely Patpat hangs around here anymore, but credit is due when it's due. Great work!
This was a totally brillant idea !!!<div>Wonder why it didn't spread like fire ...</div><div>It may be that at the time , the only option available was the air-soft gun and it was bulky enough to make the modification complicated ....</div><div>But for some of you guys using the more compact Asiatam recoil system with the high voltage flash unit ; It's rather easy and 4 wires is all you need ....</div><div>I decided to give it a try ...</div><div>I had to trim down the swivel quite a bit due to space restrictions and do some fancy weldings ; but everybody can do it ....</div><div></div><div>Here's a short video and some pics ....
<a target="_blank" href="http://youtu.be/-SaVCVwuRc0">youtu.be/-SaVCVwuRc0
<br type="_moz" /></a></div>
Were you able to get an MG leads for the coax gun? Doesn't look any of the battle system wiring would fit, either. What we really need is the same thing but with up to 8 wires.
No ; I am limited to 4 wires only ...In order to get more wires ; you need to look for "slip rings " ; but they can be expensive ...
<a href="http://shop.ebay.ca/i.html?_from=R40&_trksid=p3902.m570.l1313& _nkw=slip+rings&_sacat=See-All-Categories">http://shop.ebay.ca/i.html?_from=R40...All-Categories
<br type="_moz" /></a>I wonder how hard it would be to make our own .....<br type="_moz" />
I thought about something like this some time ago but here we have cheap ready solution. Thx for this. I plan to add this in mine tiger 1.
Looks good. A couple of questions:
How much space did you find that you have inside for the slip ring?
What are the conical springs for?
In my Panzer IV ; I had to make sure that the swivel didn't stick down in the chassis because I have a custom speaker mounted in the chassis under the turret ....That's why I had to trim the top of the swivel and do some fancy weldings on the terminals ....
But if you have a bit more space , you don't have to trim the swivel ....
Here's some extra pics to show what I was planning to do in the first place ....
The 2 coil springs are there to hold the swivel flush to the turret while living some play ...
I left some play in the system to reduce the stress on the wiring since it's hard to get the swivel a 100% centered ....
I have given some toughts on how to operate a H.L. infrared battle system in a bigger tank ( like a tiger 1 ) using a 4 wires swivel like this one ...
I'm testing part of the idea on my panzer IV right now and will be posting the results soon ....
I've considered doing something like this for my tanks. But, I like to keep them airsoft tanks. The slip rings look like decent ideas. I have to check to see if I need 6 or 8 wires, though. The other concern I had was their depth and stick too far into either the turret or the lower hull. May just have to get the most shallow one and try it out.
ORIGINAL: philipat
I have been looking for something to achieve this for quite some time
