Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
timing mod with math
Old 02-20-2008 | 10:51 AM
JB COMP's Avatar
Default timing mod with math
has anyone did timing mods by math? where you just measure the engine, then add the formula and get a timing to mod the engine to?
or is it, you just cut away till you no longer get any increase in performance then mark down what degree you stop seeing the increase?
Old 02-20-2008 | 11:41 AM
SManMTB's Avatar
Default RE: timing mod with math
1. That's what engine simulation software is used for.
2. If you have a dyno that would be another way to do it.
Old 02-20-2008 | 04:38 PM
giddyuperic's Avatar
They have a timing degree wheel you can by for the little two stroke motor that's how the big boys do it. Try Jb mods or AB mods and high performance mods.
Old 02-20-2008 | 05:23 PM
JB COMP's Avatar
I know how to degree an engine, I just need to know how to figure out the modded timing, of an engine.
Old 02-20-2008 | 05:25 PM
SManMTB's Avatar
You can study thermodynamics and then read a 700 page book about it. Look for a book by Professor Gordon P Blair.
The other way would be to spend $5000 on a dyno and a box of engines and go from there.
Old 02-20-2008 | 05:38 PM
JB COMP's Avatar
ORIGINAL: SManMTB
yeah, but the x-dyno is $6,000 and a box of engines is $300 - $2,000 or theres another dyno thats $10,000 - $12,000 plus the software to run it which is $2,000 - $3,000
giddyuperic, I did a search on JBmods and nothing came up (or at least not on RC engine modding)
Old 02-20-2008 | 05:55 PM
SManMTB's Avatar
JB, what are you actually looking for? To me it sounds like you are looking for KNOWLEDGE and that can only be had by studying, trial and error + money and time.
There are no shortcuts, there is no simple formula where you enter desired hp and torque and the current timing of the engine in your hand.
The absolute cheapest way is to buy the software I have suggested many times here on RCU and just play around with it.
I'm not trying to be a smart-ass. There just aren't any shortcuts. Nobody can in one post here say what you need to do.
Old 02-20-2008 | 06:00 PM
JB COMP's Avatar
well, there is one for induction timing, so I thought there might be one for port timing. but if not, then oh well.
Old 02-20-2008 | 06:03 PM
SManMTB's Avatar
What are you saying?
There is no formula for induction timing that tells you what numbers are the best, because the actual power and torque output of an engine is a combination of everything...
Can you be more specific? I don't get what you are asking.
Old 02-20-2008 | 06:17 PM
JB COMP's Avatar
isn't this http://www.rcuniverse.com/forum/m_59...tm.htm#5995115 where you just measure it then, do some math, and it gives you the degree to cut to, or did I miss understand it?
Old 02-20-2008 | 06:23 PM
SManMTB's Avatar
Yes that is correct. It's just that your original question was unclear.
Yes there is a formula to calculate what timings the ports have based on dimentions (bore, stroke, length of conrod and height of ports).
If you know some basic trigonometry you can easily come up with it yourself, I'm just to lazy to spend time and post it here.
Old 02-20-2008 | 06:46 PM
JB COMP's Avatar
I was hopeing someone already had it rote down, then I could put it in a spreed sheet then I could just stick my measurements in there (bore, stroke, length of conrod, etc) and it do the work for me, since I haven't taken trig yet.
Old 02-20-2008 | 06:50 PM
SManMTB's Avatar
Yeah but wasn't this part of your school work LOL?
Old 02-20-2008 | 06:55 PM
JB COMP's Avatar
well yeah, but that was the day I skipped
just kidding, no it nots, and I'm only taking Algebra, and I'm only a B sometimes C student in it, somethings I can get 100/100 on but somethings I get 60/100 on and then sometimes only a 20/100 on it.
and I think next year I'm taking business math or something like that.
Old 02-20-2008 | 07:25 PM
SManMTB's Avatar
Umm, you're 14 right? Business math!?
Old 02-20-2008 | 11:29 PM
JB COMP's Avatar
yeah, so I don't have to take trig.
yup I'm 14 almost 15.
I was hoping savagejim would post here, since he did the induction timing, so I thought he might have one for the port timing.
Old 02-21-2008 | 12:39 AM
hey sman,
y do u find it nessicary to post replies to modding engines when u don't answer anyone u just try to make that person feel dumb and make yourself seem smart. i thought these forums were here to help people, and not to discurage people from triing new things in this sport.
Old 02-21-2008 | 01:27 AM
SManMTB's Avatar
If you read many earlier post from me you will find that's not the case. I'm actually trying to steer him in the right direction.... read between the lines dude.
It's not in my intention to make anyone feel dumb, because I don't think that is the case. He's not dumb.
Old 02-21-2008 | 09:56 AM
JB COMP's Avatar
ORIGINAL: SManMTB
depends on who you ask
Old 02-21-2008 | 10:44 AM
SManMTB's Avatar
OK dayglo, here we go.
Here's a picture to go with the formuals:
Variables:
R = length of conrod in [mm]
D = Stroke/2 in [mm]
P = piston position relative to center of crank in [mm]
X = crank pin postition relative to center of crank in [mm]
alpha = crank angle in [deg]
Formulas:
In the picture we can see that:
P = X + T
where
X = D x cos(alpha).
To calculate T we need the help of phytagoras formula that says:
R^2 = T^2 + T2^2
Solve for T and we get:
T = SQRT(R^2 - T2^2)
T2 can also be expressed as:
T2 = D x sin(alpha)
which gives us:
T = SQRT(R^2 - (D x sin(alpha))^2
Finally we get the expression for P as a function of crank angle alpha:
P = D x cos(alpha) + SQRT(R^2 - (D x sin(alpha))^2)
Now you can insert: D = Stroke/2 (but I won't do that, it makes it cluttered to read)
Hope this helps.
Old 02-21-2008 | 10:51 AM
SManMTB's Avatar
There's an error in the picture. The angle alpha should be between the black line and the vertical red line, not the horizontal.
Old 02-21-2008 | 11:32 AM
JB COMP's Avatar
so that will will give me the timing to mod too?
Old 02-21-2008 | 11:41 AM
SManMTB's Avatar
This will give how the piston moves up and down the stroke depending on crank angle. No you need to measure what distance from the top of the liner the piston is at TDC to get a reference point for that and then you use the value (P) to add and subract from that when you decided at what point a port opens after TDC for example.
I am not going to do the rest for you.
Old 02-21-2008 | 11:48 AM
JB COMP's Avatar
ok, let me see if I'm understanding this right. this will tell me how far the piston goes up the sleeve, when I decide when I want the ports to open. is that right?
Old 02-21-2008 | 11:51 AM
SManMTB's Avatar
It tells you were the piston (actually wrist pin) is relative to the center of the crank shaft as a function of crank angle.
