Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
 Nitroplanes Tucano >
Nitroplanes Tucano
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Nitroplanes Tucano
Old 03-18-2008 | 08:27 PM
Default Nitroplanes Tucano
Has anyone purchase one yet? They are having a sale on these and others. Are they good or bad? Anything else you can tell me. thanks Lenny
Old 03-18-2008 | 10:13 PM
opjose's Avatar
Default RE: Nitroplanes Tucano
See this thread and check out the link towards the bottom.
[link=http://www.rcuniverse.com/forum/m_6300298/anchors_6300298/mpage_1/key_Nitroplanes%252CTucano/anchor/tm.htm#6300298]Click me![/link]
Old 03-19-2008 | 02:17 AM
Gregor32's Avatar
Lenny, also have a look at http://www.rcuniverse.com/forum/m_58..._tucano/tm.htm some more info. enjoy Greg
Old 03-19-2008 | 09:54 PM
Thanks for the info. Keep it coming. In the meantime, I'm thinking about getting one, since the price is now $139.00 + shipping. What do yous guys think? Lenny
Old 04-10-2008 | 09:18 AM
hi, I am building an embraer nitroplanes. The instructions are incomplete. There are many problems in the kit. However I believe that the paid price is worth. I will advise after the first flights.
Old 04-10-2008 | 10:35 AM
I have one and it flys fine. It's a little under powered for me (Eflite Power 60 - electric), but is a great flying plane. Lands very fast even with full flaps. I have Spring Air retracts on it and they work great. No problems so far, just need more power. I may have to go gas on this one.
File Type: jpg
File Type: jpg
Old 04-10-2008 | 08:36 PM
hi, beautiful the embraer in photo. The kit that I have bought is not predisposed for the retractable landing gear. Will Nitroplanes sell it in the future? Will be possible to only buy the wings? Does someone know? Regards
Old 04-14-2008 | 11:29 AM
It wasn''t hard to add the retracts on mine. If you want one with retracts installed buy a KMP Tucano.
Jeff
Old 04-14-2008 | 12:03 PM
Jeff, thanks for the answer. I knew about kmp, however incredibly expensive. Please let me know which type of retract that you have installed and what procedure you have followed. Rgds
Old 04-14-2008 | 12:55 PM
I installed Spring Air retracts for the mains and nose gear. You could also use mechanicals, but it would be more work on the nose gear. The wing install is easy just install the blocks and some light ply. The nose gear took some creativeness to get them installed. I used an old set of gas engine mounts to install the nose gear on. Went fine after that.
Jeff
Old 01-02-2010 | 06:39 PM
Hey Guys
Anyone know where i can get a instruction manual for the tucano 120 65 in. span?
James
Old 02-07-2010 | 11:18 PM
See my pictures of Tucano flies beautifully
ID:	1374134   Click image for larger version
ID:	1374135   Click image for larger version
ID:	1374136   Click image for larger version
ID:	1374137   Click image for larger version
ID:	1374138   Click image for larger version
ID:	1374139   Click image for larger version
ID:	1374140   Click image for larger version
