tiger 1 rebuild
Old 04-17-2008 | 03:47 PM
Banned
Default RE: tiger 1 rebuild
lanierrl,
I used a choc block connector to connect the 4 extra wires from the proportional smoker to the motor feeds then connected it to the Elmod board, because the wiring points on the elmod board are not big enough for two wires
Old 04-18-2008 | 06:40 PM
Banned
the proportional smoker runs as a normal unit controlled via the 4 extra wires. it gets its power from the HL board.
Old 04-24-2008 | 03:20 PM
Banned
I have fitted the track adjusters and the track now stay on the wheels and do not try and jump of the rear idler
a few pictures showing the backing plate and bolt fixings for the track adjusters
the top two bolts hold the plate to the tank body side
the bottom one is the axle for the adjuster
and the one at the bottom edge of the backing plate locks the axle in place hopefully stopping it from rotating and the track jumping
ID:	936124   Click image for larger version
ID:	936125   Click image for larger version
Old 04-28-2008 | 04:59 PM
Banned
also I forgot to mention that I have removed the smoker so if any one wants a proportional smoker drop me a line in the usual fashion
Old 04-28-2008 | 05:10 PM
Banned
Looking good Brel
those idler tensioners look real strong [)]
Rob
Old 04-28-2008 | 05:43 PM
  #31
Banned
ORIGINAL: fv432
Looking good Brel
Rob
I just hope that they are not too strong that they break the lower hull
Old 04-28-2008 | 05:46 PM
  #32
Banned
you could if you were worried about it bolt a piece of "L" angle to the bottom bolt and bolt/rivet it to the floor
might give you a bit of piece of mind
Old 04-28-2008 | 07:40 PM
  #33
Banned
ORIGINAL: fv432
I might just do that yet, just got to make my mind up.
Old 05-17-2008 | 03:04 PM
  #34
Banned
Had a surprise today when i got home from work at 6pm, my order from backyard armour turned up, I had completely given up on the order, i only ordered the parts about three months ago so will be fitting them to the tank in due cousre
