Yellow Spitfire wing
I'm gathering material to start this project sometime next year. Was wondering about the wing. It is already sheeted, does it have a spar running thru it. I like to do fast low fly-bys then pull up. Just want to make sure I dont fly beyond the structure design limits. Planning on a DL50.
Edwin
Edwin
The wing comes pre-sheeted but no spar. A DA 50 shouldn't over stress the airframe.. The wing is glassed with heavier glass cloth out to the wheels and then lighter cloth after that. Just use the lighter cloth on the entire wing to get a smooth transition. It's an excellent flying plane..
My Feedback: (34)
You will eventually over-stress the wing as designed. The glass layers on the bottom are not adequate to handle hard pullouts. I have stress cracks in the glass on both sides. I fixed them after about 100 flights with another layer of glass and re-painted the whole bottom. They showed up again. I am at 208 flights and have the cracks. I just pull up smooth and gentle now. The same cracks showed up on my son's Yellow Spit as well. It is a design issue. We are building another new spit now and have changed the whole front spar joiner to carry more load. It is a 1/8" ply spar that runs all the way through the center section and out past the gear mounts in the wing. Lightening holes applied in some areas. From 6 seasons of flying Yellow Spitfires I judge this as a required modification. Leo
Hi,
I use 2-oz cloth for the bottom of the wing. I overlap it from the tip to about 8 inches outboard of the joint, so that the entire center, plus 8 inches outboard on either side are glassed over with two layers of 2-ounce. Plenty.
Hey, I resemble that remark!! Hows it going, birdie?<g>
Thats what I needed to hear, some long term experience. I had planned on using some 4oz glass I have laying around. 8" past the joint sounds like a reasonable thing to do also. Is an 1/8" ply spar enough? I was thinking more along 3/16" or 1/4".
Edwin
Edwin
Edwin,
All's well. We're running our scale meet this weekend. Flying the PT-19. Went up to Wenatchee WA for their Scale Master's Qual, and placed first in fun scale. Tim's about ready to shoot paint on his Mopevy. Once he's done with that project, it will be back on planes. I'm in the middle of a 1/5 109. I have a half built Vally Tempest for Tim to finish up when he's done with his car. Then there's the Ziroli Corsair kit and extra's I gave him, and I have an unstarted (except for the bubble canopy conversion) Yellow Spit. After that, who knows?
Know what you mean. Tim was pretty disturbed when that viper almost beat him. Whats he up to now, 650hp? That car was scary before he tore into it.
The yellow spit is a next year or two project. Gotta finish that busa 1/4 scale J3 and L4, then finish the TF P-47. The last struts I made for the P-47 didnt turn out so good so I set it aside for a bit. Got a GP Yak54 ready to play with and big sundancer bipe, those are for playing around with. ARCA done made me a CD, I do the warbird event now.
Edwin
Edwin
My Feedback: (34)
ORIGINAL: Edwin
Edwin
Edwin
Full height spars is pretty much a given, I agree. I would have expected the crack on the bottom, looks like it on the top. I have a lot of experience with probond and gorilla glue. Probond was used on a wing mfg P-38 foam wing sheeting years back, love that stuff. Gorilla glue was used to build my airplane trailer. I will probably do the spar fix early on. It doesnt sound like a big hassle. Just cut a slot, stuff it with spar, fill it with polyu glue. I learned that its much easier to wipe off the expanding glue as it happens within the first hour. The probond dried pretty hard and had to use the dremil to remove the excess.
Robert,
I already have the kit.
Edwin
Robert,
Edwin
My Feedback: (34)
That is the bottom in front of the gear mount. The structure you see on the left is the belly scoop. No cracks on top.
I apply masking tape over the balsa on both sides of the joint and then wipe off the excess against the tape. It makes clean-up so much easier plus you don't soak the balsa. Leo
