Juno RC F-18 Build and Mods
YT, CANADA
OK we know that the F-18 as is will fly and is a very cool kit to build .... BUT ....I am going to build one
with some mods.
So I placed a order and looks to be a two week back order before I even get going ...then add 3 weeks for shipping ...so if I am Lucky it may show up the end of November.
My list of mods
1) Shorten fuse by 3" aft of the TE so it will move the Fins closer to the wing and look more scale. ( this has been done by a fellow in Australia and flew well.)
2) Shorten wing by 1 1/2" each side.
3) Shape the LEX to mold well to the LE of the wing.
4) Dual place canopy
5) Using Spring Air retracts move stock location back so the spring will face forward and retract forward as well
6) A better control method using one servo for the Rudders or none at all and fix rudders in place.
7) Remake the Ailerons so they are wider at the fuse sides and smaller outboard.
8) ???????
Add to the list if you like and let me know about the ones I have picked to try.
Power ....what engine to use?
with some mods.So I placed a order and looks to be a two week back order before I even get going ...then add 3 weeks for shipping ...so if I am Lucky it may show up the end of November.
My list of mods
8) ???????
YT, CANADA
It will be close ..not sure if I can droop the LE
as a matter of fact I know I can't ... mind you one fellow has made some for the SU27 from AK Models. Maybe I can send him the wing for the mod [X(]
My Feedback: (32)
I have a DC F-18 {same plane} built as instructed. Power is a ST .90 with a Mac's header, uncut and a Mac's quiet pipe. 12 X 8 Zinger prop. Great power package!!! Ultra reliable!!!
Mechanical retracts. They work, but are a pain. Always something wrong every flight.
Awesome flying plane. Fly's like it is on rails. Sloppy rudder linkage is not a problem, so far.
I was so happy with the first few flights that I bought a Juno F-18 and another ST .90.
This one will get Robart Retracts and some of the mod's you are thinking about.
Don't eliminate the rudders, they are very effective and add to the WOW factor when used in a low flyby.
Tony
Tony
Looking forward to your build. I purchased the kit from Derek when the dollar was better. I'm finishing off a F-18 pusher (RCM 0.40 plans )at the present time.
Jim
Jim
YT, CANADA
"Tony" ...Thank your for the input ..keep it coming when you think of it ..and how about a Picture of the F-18 you have now?
"Jim" ... Yeah the dang dollar has me about 126.00 for the kit ..oh well... Can you post a picture of what your pusher F-18 looks like? that would be great.
All F-18 pictures are welcome besides I need some ideas for the finish.
Thanks Pete, I've been following your builds of the Midwest Striker and the AK Model. My F-18 is constructed from Mike Pastro's plans featured in RCM magazine. I have a build thread in the scratch build section. I'm getting to the ultrakote stages. You might find something helpful. I like the lines for the fuselage on the Junorc kit, except for the flat lex. I had to build mine up on the F-18. It wasn't too detailed on the planes. I show how I constructed them on the build thread. I would like to make another pusher as an electric model with plug in wings. If this one flys ok.
[link=http://www.rcuniverse.com/forum/m_4763576/tm.htm]RCM F-18 Build Thread[/link]
Jim
Jim
How about this? The interesting fact about some of the Canadian special paint schemes is that the (Jim Belliveau) designer's brother Mike is a member of the rc club I fly with.
ORIGINAL: Blade47
YT, CANADA
Thanks Jim! you have a good start on the plane all right. I have done the F-16 in a similar scheme so will put this one on the maybe list.
I plan on beefing up the Lex as well.
I will drop by your thread and have a read.
YT, CANADA
Have to think about the dimensions to get it to look a bit more scale.
Cemark Wingspan 47 in
Length: 61.5 in
Wing area: 596 sq in
Weight: 8.5 lbs
Juno RC Wingspan 53.0 in.
Length 59.0 in.
Wing Area 642 sq. in.
Weight 7.5 - 8.5 lb.
My Mods Wingspan 47 to 50.0 in.
Length 56.0 in. May be able to leave the fuse length if I can move the Fins closer to the TE with out to much trouble.
Hmmmm ...any Ideas out there???
Length: 61.5 in
Weight: 8.5 lbs
Length 59.0 in.
YT, CANADA
Had a Email from Derek and looks like the kit will ship next week.... I liked the items I used on the F-16 and how well they performed that I have them on the way as well.
PowerExpander Sport
Spring Air 101HD
TruTurn spinner Black
As for the power plant and muffler ...well I have some time yet to think about it.
PowerExpander Sport
Spring Air 101HD
YT, CANADA
Raod? when you get your bathroom finished are you going to post your build in with this thread as well? That would be cool if you did.
YT, CANADA
No ....[
] ...still waiting ..but I do know that it is on the way ... maybe this week depending on Customs and how many times they open and close the box
YT, CANADA
BIG Box of wood just came in the mail
I have the plans and instructions out on the table and will dry run the build this weekend to see what I need to change up.
Need to place a order with the Hobby shop for building supplies and then I am good to go.
I have the plans and instructions out on the table and will dry run the build this weekend to see what I need to change up.Need to place a order with the Hobby shop for building supplies and then I am good to go.
YT, CANADA
OK we have a start ... Marking all parts to the plan ...this is the first time I have not seen extra wood in the kit from the cut outs ..in other words all scrap has been removed to save space and shipping I would think ..very smart...
Next working with the fuse sides marked on the former positions and moved the aft formers ahead 3" and cut off the remaining part ...changed out former #4 with #5 as it has the fin guide notched in the top plus added 1/4" balsa backing for spacing and added glue surface to cover joint along with the 3/4" tri stock.
I need the nose gear now to drill and mount the gear into place before I glue into the fuse sides.... so will turn my attentions to the wing for now.
YT, CANADA
A wing is wing is wing ..still waiting for the retracts to work on the fuse ... have a couple things planned for the wings that I am just working out now,
YT, CANADA
Placed a order for stuff from Edmonton HS and will ship next Monday ... retracts still not here ...Will be working on joining the wing half's this week and have them ready for full sheeting when my order comes in next week. I have also removed the outer wingtip bay on both sides and reduced the wing to 47"
Hope everybody had a great holiday
Cheers
Cheers
YT, CANADA
Good news ...retracts are on the way ...would think they will take two weeks to get up this way ...lots of time to finish the wing.
YT, CANADA
Wing is sheeted in and have pictures to post tonight.... I have some NO BS batteries on the way ..has any one used them? I have a 6V 5 cell 1100 ma RX and 8 cell 1100 ma TX on the way.
Cheers
Cheers
NJ
ORIGINAL: Blade47
Cheers
Cheers
just got 2- 6v 5c 2000mah for the boomerang sprint. You are gonna like them.
YT, CANADA
Looking forward to using the batteries then PH.
I should have the wing finished this weekend .... just need to make the control rods ...cut out the section for the fuse to slip into and do a nice clean up sanding.
You can see the outboard tips that I removed.
