My next project has started: Grum Me262
Here are the pictures of my next project:
the wing structure:
The nomex/carbon sandwich frames:
This aircraft is based on the fantastic Grumania kit. I got it at a prototype stage, so it is a kind of semi-kit for me.
This is what I wanted, since I will be able to do it "my way".
The quality of the kit is fantastic and compares to Skygate Collection products.
The structure has been designed to be as light as possible and the plane will be around 13 kgs dry takeoff weight and 16 kgs full takeoff weight.
The load sheet is available here:
http://www.geohei.lu/olin/data/model...eet%20P-60.xls
I will power the bird with a pair of P-60SE. The engines are at the factory in Germany for pairing and servicing.
the wing structure:
Is it my imagination, or is the nose shorter than scale?? IF so, is that just a prototype dimension?
Sorry, it will be a very cool project either way...but I'm almost certain they've goofed up the nose lofting. I hope U don't mind my pointing it out
I can't tell you about the nose section.
When I work on a scale project I take a lot of time to study the plane.
I have 7 books talking about this plane including the scale drawings and it has taken me a lot of time to read the amazing story of this plane.
Unfortunately I have not studied the drawings yet, mostly because the F-84G is still sitting on my workshop table.
When this one is totally finished, I'll be able to set it up properly on the table and verify the dimensions.
ORIGINAL: highhorse
The photos in the thread are taken at an angle so it's hard to tell if the nose is right. Using the floor tiles as a guide, and comparing the length of the nose to the engine nacelles it doesn't seem to be far off from the three-view.
Oliver, finish the F-84 and check this out for us.
By the way, is the food still excellent at the Dubai Golf and Country Club? I had absolutely best "chicken fingers" in the world there for lunch one day!!!!! The Aviation Club buffet was pretty amazing too!!!!
Regards,
Jim
ORIGINAL: rcjets_63
I thought the same thing so I pulled up a three-view. Viewed from the side, the nose looks long & thin. Viewed from the top, the nose looks stubbier.
Regards,
Jim
Regards,
Jim
The only way to make sure about this is to check it on the bench. However, knowing Ilja, I strongly doubt there is a mistake on this section ( he has the original certified drawings and is very precise in his work... )
ORIGINAL: tp777fo
Oliver, you need to quit building so many of the easy ARF projects and build a real "builders kits". Looks like a great project...bring it to Waco next fall for the SW jet rally so we can all enjoy looking at your work. Have a Merry Christmas!
I'm afraid it's going to be hard for me to bring a jet to the USA next year since I have a big professional deadline to meet. It is likely to get me out of this hobby for half of the year...
Here is the list of equipment I am planning to put in this plane:
2 P-60 SE with cross link software and equipment
A 35 Mhz Weatronic receiver with GPS + gyros
6 JR 8611A for the wings
2 DS 3421 on the elevators with short pushrod connexions
1 DS 8611A on the rudder, 1 DS 8411 on the nose wheel steering
2 kevlar tanks in the fuselage ( 2,2 ltrs each )
Jettronics gear and break valves and 3 BVM micro pneumatic switches for the gear doors ( no sequencer )
1 Tamjets gear failsafe
I will make the following:
Carbon/Nomex frames for most of the internal structure
Scale hinges made of 2mm carbon sheets
all of this will be CNC cut
Scale cockpit around the 1/5th scale pilot that Ilja will provide to me soon.
Scale bombs/rockets depending on the version I'll choose.
At the moment, I am looking at making the all aluminium prototype version with Flight Metal.
Hello guys,
just got this video from my college Heine Skroblin.
http://www.youtube.com/watch?v=gpmkv3renxA
He managed to get the Stormbird electrified ! Two Deiss ducted fans, take off weight 17 kilogramms.
Congratulations Heiner!
Ilja
Ilja
ORIGINAL: Eddie P
Oliver, this looks to be another masterpiece in the making [&:]
I have just resumed the works again.
I have almost all the components now. The engines are back from Germany and have been cocooned by Max and his team. Should be great.
I have finished the drawings of the tail section setup ( superlight carbon/nomex sandwich structure housing two DS 3421 for the elevators control ).
I am now working on the engine nacelles and wing center section.
Are you going to be at the CA Jets ?
ORIGINAL: olninco
...Are you going to be at the CA Jets ?
ORIGINAL: dw_crash
Great Project......
Which vendor did you get this kit from? I have a pair of Hawk-14 turbines fit for just a plane.
DW_Crash
Great Project......
DW_Crash
ORIGINAL: Eddie P
Absolutley. Any chance you'll be in the (western) states in early April?
ORIGINAL: olninco
I'll be in Houston on the 30th of March and I have requested days OFF to make it for CA jets. Will have my roster on the 26th...
Some update:
The carbon/nomex formers and kevlar tanks
The nose formers and gear assembly. Basalt fiber/plywood sandwich.
Hi Oliver
Good to see some photos of your 262. I took delivery of mine last week and I've been "exploring" everything and have heaps of questions and things to resolve. Have you decided how you will mount the engine nacelles? I'm thinking of making these detachable which will require some extra stucture and mounting points.
Anyway, I'm keen to follow what you are doing.
cheers
Rod
cheers
Rod
Hello Rod,
the latest version of the manuals will have this covered.I have send you the corresponding pictures in a PM.
Ilja
PS : the new jet pipes are under construction and I have decided to make double walled convergent/ divergent ones as a standard. This kind of pipe will produce a thrust gain of about 8 % !
Ilja
ORIGINAL: teamkaos
Hi Oliver
cheers
Rod
Hi Oliver
cheers
Rod
I will probably go for a shear pin mounting method for the nacelles.
The middle nacelle former can be moved and extended to go through the center wing section. I would then use two 6 mm carbon pins to hold the former at the back of the front spar.
A former should be made to seat aft of the rear spar location. A 4 mm nylon screw could be used to fasten the rear assembly. The holes in the outer rib center section would be usefull to fasten the screw.
I have just finished writing an detailed article for the next RCJIpublication . I tried to make it complementary to the excellent building manual from Ilja...
In any cases I'd be more than happy to help you and answer as many questions as you want.
ORIGINAL: olnico
Tom, I used to design jet kits for AD. I must say that I have enough of this and I'd rather spend time on assembling kits and enjoy quality finishing and flying.
ORIGINAL: tp777fo
