SYSSA 30CC GAS MADE IN USA
Old 10-26-2009 | 06:34 PM
  #951
PlaneKrazee's Avatar
My Feedback: (14)
Default RE: SYSSA 30CC GAS MADE IN USA
ORIGINAL: GSK
Re the 18*10 if it pulls at least 7500 on the ground then that will be comparable to an FX 160 which is good .I would just like that confirmed
Regards
Graeme
My 160fx spins a Bolly 18X10, Mejzlik 20X6 and Bolly 16.5X10 all at 7800 rpm on an extremely quiet Jtec dual snuffler and 5% nitro using at least twice as much glow fuel as the Syssa will use gas.
A friends fx spun his Mejzlik 18X6 @ 10,000 rpm. Can you say loud!
Old 10-26-2009 | 06:51 PM
  #952
My Feedback: (7)
I have 3 different OS160 FX motors and they all tach right around 8000 with the 18.1x10 APC.
RC
Old 10-26-2009 | 07:00 PM
  #953
My Feedback: (14)
ORIGINAL: RC11
RC
On a pipe or muffler? That would be on a Aeroslave tuned pipe and Karl Mueller header?
According to ThrustHP the Syssa 180 makes 3hp on the stock exhaust @ 8750 rpm which is .36hp stronger than a G-26 according to the Horizon website.
I have a OS 140 pipe, not the best set up for gas but will run the engine on it and a custom header for tach purposes. I emailed ES tonight and asked which pipe he would recommend for the SAP 180.
Todd,
What is the center to center distance of the exhaust bolts and width and height of the exhaust port? Is it round or rectangular. I'd like to make the header and have it ready for when I get the engine.
Old 10-26-2009 | 10:06 PM
  #954
My Feedback: (14)
Old 10-27-2009 | 07:19 AM
  #955
My Feedback: (7)
ES pipe or cut down JTEC pitts. 8000.
RC
Old 10-27-2009 | 07:43 AM
  #956
My Feedback: (14)
APC 18.1X10 or 18.1X10W?
Old 10-27-2009 | 10:51 AM
  #957
My Feedback: (7)
LP18110 is the manufacturers #. Not the wide.... LXRCJ4 is the Tower #.
RC
AMA 1111 NSRCA 4116
Old 10-27-2009 | 12:34 PM
  #958
sgillmore's Avatar
My Feedback: (50)
DamonR or Tsyssa:
Just wondering...did the SAP-180 in the Sundowner videos have the Muffler Tone Inserts installed? Do the insert just make it quieter or do they change the tone too? Thanks.
Old 10-27-2009 | 12:42 PM
  #959
The sundowner did not have the inserts. It does change the tone a bit...but makes it noticeably quieter. At 25 Feet away it drops 9 db.
For other specifics, it would take a few minutes to go through all the other data...
Old 10-27-2009 | 12:58 PM
  #960
sgillmore's Avatar
My Feedback: (50)
ORIGINAL: tsyssa
Thanks for the info Todd. Have any videos been shot with the inserts in? Just curious about what it sounds like.
Old 10-27-2009 | 01:02 PM
  #961
AJsToyz's Avatar
Todd,
Can I still add the tone inserts to my order before you ship ??
Andy
Old 10-27-2009 | 01:16 PM
  #962
No problem...
Old 10-27-2009 | 01:49 PM
  #963
DamonR's Avatar
Hi Todd,
When is the next speed run? Did you get the new prop to modify? How about an airspeed sensor (an Eagle Tree sensor is $42)?.
Are you going to chop the exhaust before we race? We leaned out the MVVS when I flew Sunday afternoon in Simsbury, it should be closer to 14,000 rpm now. I might need to make some cowls around my servos and tape the vertical stabs to clean up the airflow flow. The Sundowner looks faster and I haven't seen you dive into a down wind run yet.
Damon
Old 10-27-2009 | 02:01 PM
  #964
I have to get one of those. In about a 25 degree dive its doing around 165...
Straight and level at full power its probably somewhere around 140. The engine is new and the prop is not loading it near enough. When I get the 12 x 16 pitch on there...then we will really find out. Right now I just want to get used to the little screamer.
We WILL race!!
Im too afraid to put it into a steep dive yet LOL!!!
Do you know if anyone makes a small diameter 18 pitch prop I can modify?
Old 10-27-2009 | 02:46 PM
  #965
My Feedback: (16)
What a work of art! Keep up the hard work...I'm down for one!! The price point is very attractive for such enginering and quality and it is just GREAT YANKEE PRIDE !!!! Good for you. If a 60 is in the offering sometime soon I'm a player for that one too!!. Yahoo!!! Yankee pride and craftsmenship shows the way again. What a true DEAL for this thing.
Old 10-27-2009 | 05:10 PM
  #966
My Feedback: (14)
ORIGINAL: tsyssa
Todd,
You might want to try a solid carbon Bolly14X16 prop. They can be modified. Thrusthp; 3hp @ 8850 rpm, pitch speed 134 mph. "High speed prop for 1.20 use". Aero Products in Dacula, Georgia says they have them in stock. http://www.aeroproduct.net/
Ed Skorepa recommends the ES26G carbon pipe.
Regards,
Brian
Old 10-27-2009 | 06:22 PM
  #967
Right now...its turning a 14x14 APC on the ground at 9300 rpm and it has about 4 flights on it...basically a new engine. In the air its unloading somewhere around 11,500 - 12,000 rpm. This is on the stock muffler.
I might have to put a Skorepa pipe on this little guy. Im afraid the end of the pipe though will be close to the tailwheel LOL.
Thanks for the prop suggestions...I will likely try the Bolly and trim down...as I do not need the extra diameter.
Old 10-27-2009 | 06:26 PM
  #968
The little Sdowner airframe is basically all stock too. I would really like to put some thinner wheel pants on it. The wheels and pants are HUGE for this plane. It takes the same size front wheels and pants as my AW Yak 73"!!! Actually the ones on my AW Yak were about 1 oz lighter in total.
Old 10-27-2009 | 07:12 PM
  #969
My Feedback: (14)
Todd,
Maybe you can pick up some solid pylon wheels and make the pants out of balsa. 1/2" contest cut out for the wheel sandwiched between 1/8" sheet reinforced with 1/32" ply around the axle. You can use the profile of the original pant and they will look nice.
Old 10-27-2009 | 11:17 PM
  #970
GoeKeli's Avatar
My Feedback: (18)
Retracts!!!
ORIGINAL: tsyssa
The little Sdowner airframe is basically all stock too. I would really like to put some thinner wheel pants on it. The wheels and pants are HUGE for this plane. It takes the same size front wheels and pants as my AW Yak 73''!!! Actually the ones on my AW Yak were about 1 oz lighter in total.
Old 10-28-2009 | 05:15 PM
  #971
MikeAndersonCA's Avatar
ORIGINAL: tsyssa - Right now...its turning a 14x14 APC on the ground at 9300 rpm and it has about 4 flights on it...basically a new engine. In the air its unloading somewhere around 11,500 - 12,000 rpm. This is on the stock muffler.
Is this with a stock engine or one of your "race-ported" protypes. If this is stock then MAN! that's amazing.
Old 10-28-2009 | 05:38 PM
  #972
This is an all stock SAP-180HP, just like everyone else gets...even the muffler is stock...did not even cut the outlets shorter yet for less air resistance.
This is a project to push the SAP-180HP envelope for our own design purposes (of course there is some fun in there too).
Oh...Damon, maybe this weekend we can race....my dad fixed the firewall of the little sundowner 50 (he used the West structural fillet system) and epoxied where H9 forgot to. I should have looked it over more carefully...but now at least...there are no more worries.
Maybe this Sunday we will have to video tape a full throttle close in fly-by. need to race you flying wing!!!
Old 10-28-2009 | 08:45 PM
  #973
ORIGINAL: tsyssa - This is an all stock SAP-180HP, just like everyone else gets...even the muffler is stock...did not even cut the outlets shorter yet for less air resistance.
OK that's it I'm not gonna hold out for the race-ported version - I just ordered an engine!
Old 10-28-2009 | 09:46 PM
  #974
Did final setup and ran engine in shop today, high rpm 82500, low 1600. Was harder to get gas pumped up to get wet engine for starting than on stand, maybe a little lean on low end ? The engine only has 1.5 hours run time. It was very windy 20 to 30 north wind, if wind goes down will go flying tomorrow.
Old 10-28-2009 | 10:31 PM
  #975
Here's some more pic's of the motor installation for the Funtana 125. The only things I have left to do for the motor is cut the hole for the choke rod that will exit the bottom of the motor box and seal all the exposed wood. Then the electronic ignition will be next. I already have all the servos for all the control surfaces installed .
When I received my Funtana 125 the nylon control horns were missing from the kit. I contacted Horizon two weeks ago and advised them of the problem. The horns were out of stock. Today, I received an email from Horizon advising me the parts are in stock and being shipped. Now I have every thing I need to complete the build.
I'm still about 3 weeks away from having it done. I'm not going with the CA hinges, I"m going to use Dubro's instead, so I'll have to drill all the holes for it and re-enforce as necessary.
Regards,
Chuck
ID:	1304049   Click image for larger version
ID:	1304050   Click image for larger version
ID:	1304051   Click image for larger version
