 CMP 80" Zero Bash***** >
Old 09-08-2009 | 11:11 PM
77chickenhawk's Avatar
Default CMP 80" Zero Bash*****
A couple weeks ago i got another Zero and I thought I would post the bashing that gets done.. this time I'm going to get plenty of pics' the first one that i built was a real sweety but I never got any pic's of the thing befor its komikaze death on the 7th flight.. Im sold on how good a Zero fly's so one this one i deside to relocate the mains ( as done the first time, fix the flapps, Ailerons and maybe even a retractable trailwheel. donno about that one quite yet tho. All you see today was done in about 4or5 hours. turned out good enough for a daily flyer that i hope that this one will be. probably tomorrow night I'll fix the ailerons.. but thats not a biggy.
ok here you guys go. the pics are pretty self explanitory
ID:	1271482   Click image for larger version
ID:	1271483   Click image for larger version
ID:	1271484   Click image for larger version
ID:	1271485   Click image for larger version
ID:	1271486   Click image for larger version
ID:	1271487   Click image for larger version
ID:	1271488   Click image for larger version
ID:	1271490   Click image for larger version
Old 09-08-2009 | 11:49 PM
tailskid's Avatar
My Feedback: (34)
Default RE: CMP 80
Look'n good!
Old 09-09-2009 | 12:06 AM
Default RE: CMP 80
OK I just got one question , The last zero that crashed and went all kamikaze on you was there a pilot in the cockpit and was he wearing a bandana ? ok two questions LOL
Nice work ! I'm doing a 120 size CMP Zero in another thread on here didn't get as involved as you are , but this is my next project So I'll be looking on for sure
Old 09-13-2009 | 12:13 PM
Default RE: CMP 80
About half way in the landing gear section. i lined the area where the gear will be mounted (photos) with 3/16 ply and the landing blocks are halfinch ply.. after the location is set in stone , i'll gusset the blocks to the wing. ill post later. had a friend (on sight signs) print a outline of the real zero and matched up the location for the gear. the thin ply where the wheel is is for added strength just incase the gear slapps the top of the wing. i have about 3/16 clearance but you never know + its there for the fuse, thats where the fuse rides on the top on the wing.
ID:	1274268   Click image for larger version
ID:	1274269   Click image for larger version
ID:	1274270   Click image for larger version
ID:	1274271   Click image for larger version
ID:	1274272   Click image for larger version
Old 10-13-2009 | 11:38 PM
Default RE: CMP 80
a quick update on the zero. the gear is completed, ailerons finished. the wing is glassed with 2 oz cloth and finished with a resin coat.yesterday i started on the front leading edge on the fuse. the fuse came all squared off and fake looking so i cleaned that up and also reinforced the wood where the dowlpins go into. it was made with only 1/4 ply so i doubled that up and thought about useing aluminum tube, like yellow does for added stregth....
ok that is..it[sm=thumbs_up.gif]
ID:	1294744   Click image for larger version
ID:	1294745   Click image for larger version
ID:	1294746   Click image for larger version
ID:	1294747   Click image for larger version
ID:	1294748   Click image for larger version
ID:	1294749   Click image for larger version
Old 10-14-2009 | 11:44 PM
Default RE: CMP 80
today I added to the front of the oil cooler. now it has a more scale profile
ID:	1295217   Click image for larger version
ID:	1295218   Click image for larger version
ID:	1295219   Click image for larger version
ID:	1295220   Click image for larger version
ID:	1295221   Click image for larger version
ID:	1295222   Click image for larger version
Old 10-15-2009 | 02:01 AM
My Feedback: (9)
Default RE: CMP 80
Bruce, nice touch to the oil cooler intake.
Old 10-15-2009 | 09:26 AM
Default RE: CMP 80
thsnkx John
Old 10-15-2009 | 09:57 AM
My Feedback: (65)
Default RE: CMP 80
[sm=confused.gif]Are those 1/2" Robart struts? And what length struts did you use?
Old 10-15-2009 | 10:08 AM
Default RE: CMP 80
yes. they are robarts. the length is out of the package. i didnt need to cut them at all.. they were the perfect length. i did change the sissor location tho..
Old 10-15-2009 | 11:56 AM
warks62's Avatar
My Feedback: (140)
Default RE: CMP 80
ORIGINAL: RAMFlyer
[sm=confused.gif]Are those 1/2'' Robart struts? And what length struts did you use?
Here is the setup.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMUB1&P=0
Old 10-19-2009 | 12:40 AM
Default RE: CMP 80
one step closer to paradise...lol.
I'll be useing model master paint with PCL flat clear..
ID:	1297927   Click image for larger version
ID:	1297928   Click image for larger version
ID:	1297929   Click image for larger version
Old 10-24-2009 | 10:12 AM
Default RE: CMP 80
Hey!!!? whats goin on..???[sm=teeth_smile.gif]
thought i would holler at you and post some more progress with the Zero.the wing is all mounted . instead of dowls, because how snug the wing fits to the fuse, I used 1/4-20 bolts and blinde nuts. and the same for the rear, a little bit of filler and primer and poof.2 days later...
So now im going to get the elevator and rudder glassed and cought up with the front wingand then panel lines..
Ok. so I havew a question for all the scale junkies that have watched my work over the years. well what do you all think about panel line tape that does this!!!! LOOK!! chart tape will never do this. and the glue on this,wot stay on your plane.. photos are 2 hours after putting on. and it is 25 mills thick. the Zero will be the test bed for it..this could work to be a great thing to go along with my rivets. down the road.. but im to familiar with the pains of chart tape. and untill now. it is the oly thing that is in the thickness we modelers need
ID:	1300954   Click image for larger version
ID:	1300955   Click image for larger version
ID:	1300956   Click image for larger version
ID:	1300957   Click image for larger version
ID:	1300958   Click image for larger version
ID:	1300959   Click image for larger version
ID:	1300960   Click image for larger version
Old 10-24-2009 | 11:17 AM
LDM
My Feedback: (15)
Default RE: CMP 80
The wing mounting is the nest step in my CMP Fw190 bash , did you go in from the front to align the front wing hold in screws ? Assuming with the wing on place ?
Old 10-24-2009 | 12:01 PM
Default RE: CMP 80
no i went in from the rear.. with the Zero i had a streight shot with my 90 degree drill to drill the holes streight
Old 10-24-2009 | 02:03 PM
LDM
My Feedback: (15)
Default RE: CMP 80
How did you get the holes exact ? I love to do that method vs going in from the front , its not the tools that are a concern is the exact angle of attack and allignment ?
Old 10-24-2009 | 02:22 PM
Default RE: CMP 80
to be honest. i made a template so i drill the hole intering in the same place on both lt and rt... but the rest was eyeball
but i do admit i hit the mark on the nose as far as angle
Old 10-28-2009 | 04:21 AM
Default RE: CMP 80
Hello,
I made also a big changes on my CMP Zero.. Now it have smoke system, Robart retracts, wing is covered with glass and epoxy and painted... Zero have drop tank and, I made weathering finish...
On Zero I have Zenoah 45 and till now I have almost 170 flight with it in two seasons... It is so good model....
More about Zero and, how I made all that details on my web site: www.nsmodelers.rs
Web site is on serbian language but there are many photos. Also you can find all about my Top Flite Thunderbolt and Ziroli's Hellcat, which I make right now...
Mirce
Old 10-28-2009 | 10:00 AM
Default RE: CMP 80
wing is all panel lined now and primed sunday. an all day event..lol
ID:	1303544   Click image for larger version
ID:	1303545   Click image for larger version
ID:	1303546   Click image for larger version
ID:	1303547   Click image for larger version
Old 10-28-2009 | 12:48 PM
G-Pete's Avatar
Default RE: CMP 80
You're just a busy guy...looks to me almost every two weeks you have another bird on the bench.
One tip, get the car in the garage done - then you have more space for airplanes[8D]
Old 10-28-2009 | 03:38 PM
Default RE: CMP 80
oh if i could get the beast in the garage done i would.. its 3/4 done on complete redo. im about 5k short and 100's more hours to get her done. its been sitting for 5 yrs now.. im letting it set aside for now. its value will never drop..
yeah ive got 3 going from one point or another. the zero is what im trying to finish. because i need the big bird flying time under my belt b4 i even think about flying the P-40....lol
Old 10-29-2009 | 04:56 PM
My Feedback: (21)
Default RE: CMP 80
Very nice, you'll love how she flys, i'v been flying mine going on about 4 years now, I did a similar bash to mine. Looking great and keep us posted. Speaking of it, nobody on here might be interested in one of these zero's for sale would ya?!?!??!?!?! I'v had my fun with it, thinking bout puttin her up for sale.
Old 11-01-2009 | 08:51 AM
Default RE: CMP 80
How did you change the sissor location? I have a set of struts I want to do the same thing to.
Old 11-01-2009 | 01:13 PM
Default RE: CMP 80
youll need access to a tig welder.....because its chromoly, brazing just getts things to darn hot. i cut off the sissor mount off the lower part of the strut and tigged it in the correct location. on the real plane the sissors are outboard but the robart ones dont allow that.. so the easyest thing was to put them on the other side, as seen. the pic with the pen is where the original location of the sissor mount was. i also bent the strut where the wheel mounts to. so the wheels are 90 degrees from the ground and also allows for the gear doors to fit and look correct..
hope this helps?
ID:	1306131   Click image for larger version
ID:	1306132   Click image for larger version
ID:	1306133   Click image for larger version
Old 11-04-2009 | 09:35 PM
Default RE: CMP 80
hey john.. hows the MoJo??????[:-]
im still able to get a little bone here and there....burried in work... ugg..
ID:	1308079   Click image for larger version
ID:	1308080   Click image for larger version
