Go Back  RCU Forums > Marketplace
Hangar 9 AT-6 Texan 60 size w Saito FA91 FS w Robart pneumatic retracts >
Old 04-09-2018, 08:28 AM
Default Hangar 9 AT-6 Texan 60 size w Saito FA91 FS w Robart pneumatic retracts
I have for sale a Hangar 9 AT-6 Texan 60 size w Saito FA91 FS w Robart pneumatic retracts! 5000mah nimh onboard ignition, 4.8v 2500mah nimh for main, Hitec HS-425bb On ail x2, elevator, for and rudder. Hitec HS-322hd on throttle. Hitec HS-65mg on Robart one-Way valve. On/off switch for onboard ignition, MAS 14x6 prop, on/off switch with charge port for main, onboard ignition charge port, external fill valve for pneumatic system, Robart Pneumatic retracts, and air tank system. Does not come with receiver. Also comes with Robert air 100 psi pump. This is a beautiful plane and flys fantastic! Can land and fly like a trainer with full aerobatics! If anyone knows about these planes and setup you know how much is invested and can appreciate it. Local Pickup only in Rancho Cordova, CA.
Corsair416 is offline
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
