Dr. Mad Thrust 90mm 12 Blade Alloy EDF 1400kv - 3600w (8s)
I found this Dr. Mad Thrust 90mm 12 Blade Alloy EDF 1400kv - 3600w (8s) EDF at an estate sale. I ran it up on a test stand and it spool up very nicely. It has been fitted with 5.5mm bullet connectors. I am not going to use it so I will let someone else use it for their project.
Features:
o Pre-assembled
o Factory dynamically balanced
o High power with superior cooling
o High quality construction
o Fully serviceable
o Fast to fit
o No housing distortion
Specs:
EDF Rotor Diameter: 90mm
Outer Diameter: 96mm
Construction: Alloy
Weight: 680g (complete unit with 4mm connectors)
Max RPM: 37,000
Motor Type: 4082 Brushless Inrunner 1400kv
Max Power: 3600w
Continuous Power: 3400w
Max Voltage: 30v (8S)
Max Amps: 115A
Max Thrust: 4.2kg
The price includes shipping. PP please use friends and family or add 3% to final sale price. Sold as is.
Features:
o Pre-assembled
o Fully serviceable
o Fast to fit
Specs:
Construction: Alloy
Max RPM: 37,000
Max Power: 3600w
Max Amps: 115A
Max Thrust: 4.2kg
