Heavily Upgraded Axial SCX10 Pro-Line Jeep Comanche 2WD/4WD Scale RC Truck w/8ch TX
My Feedback: (28)
Heavily Upgraded Axial SCX10 Pro-Line Jeep Comanche 2WD/4WD Scale RC Truck w/8ch Radio FREE SHIPPING!
Includes Detailed Interior with Scale Driver, Full Floor Pan, Radio Controlled Selectable 2WD/4WD Transmission and Light System. Ready to Run!
This Truck is a Matching design to a similarly equipped Cherokee in another of my listings.
This truck has over twenty thousand views on YouTube so you may have seen it before, along with my other rigs.
They were used to film these videos and were then placed in an enclosed glass case for display. Each truck is suspended on stands (included) at each axle to keep the tires from flat spotting.
They all have added weight to the inner wheels for better traction while climbing. Front having more weight than the rear.
Link to 2WD/4WD Upgrade Video. (video is Cherokee but same except trans color.)
(9 min 21 sec)
Link to YouTube Videos. https://www.youtube.com/playlist?lis...0C1CFB94F82983
The following is a list of just some of items used in the build:
Axial SCX10 4WD RC Truck Kit
Axial Racing Aluminum C Hub Carrier for AX10 Scorpion AX30495
Axial Racing Aluminum Knuckles AX30496
Axial Front Axle Shaft Universal Set AX30464
RC4WD R2 Enc. DIG Trans Black Z-U0022
Robinson Racing Pinion Gear Absolute 32P 23T 1723
RC4WD R2 Tranny Sideway Servo Mount & Linkage Kit Z-S0566
RC4WD Axial SCX10 R2 Tranny Conversion Plate Z-S0298
Pro-Line Jeep Comanche Full Bed Body with Custom Four Color Paint Job 3335-00
PL-C Floor Pan 12.3" (313mm) Wheelbase 3339-00 (Painted)
Pro-Line PL-C Interior 1/10 Crawler #3337-00 (Painted)
NECA "Gale" Action Figure from The Hunger Games
Tekin FXR ESC/35T Crawler Motor Combo TT2109
Duratrax Onyx LiPo 2S 7.4V 4000mAh 25C Hard Case W/Deans
W.S. Deans Male Ultra Plug 1302
FlySky FS-GT3B 2.4ghz R/C Transmitter Controller. Upgraded (hacked) with Custom Version 0.6.1 firmware (8 channels),
Voltage Regulator, Ball Bearings, 4-Pin flash header & Lipo battery mods.
FlySky 6-channel Receiver
Turnigy 1450mAh 3S 11.1v Transmitter Lipoly Pack T1450-TX-3
Hitec HS-5646WP Digital Waterproof HV MG Dual BB Servo
Axial Aluminum Servo Horn 24T AX30835
RC4WD Steering servo chassis mounting kit for Axial SCX10 Z-S0303
RC4WD Mud Thrashers 1.55 Scale Tires Z-T0100
RC4WD Stamped Steel 1.55 Stock White Beadlock Wheel Z-W0035
RC4WD 1.5 & 1.7 Steel Wheel Hex Hub with Brake Rotor (2) Z-S0529 (front)
RC4WD Stamped 1.55" and 1.7" Beadlock Wheel Hex Hubs (2) Z-S0737 (rear)
RC4WD Scale Wheel Lugs for 1.55 Wheels Z-S0104
RC4WD Scale Front Locking Hubs Z-S0194
RC4WD Scale Rear Hubs Z-S0175
RC4WD Mega Truck Universal Shaft (92mm to 130mm) VVV-S0003 (front)
RC4WD Scale 100mm White Shocks with Internal Springs
RC4WD Ultra Soft Spring Set for 100mm White Shocks
RC4WD Red Scale Shock Boots
RC4WD Super Bright Scale Light System 2 Z-E0019
Ram Rectangular HeadLights 84 (Tungsten filament like full scale)
Rcexl Optio on/off switch (for light system)
4-Link front and rear with Custom front aluminum 4-link mount
All aluminum links including:
Axial Threaded Aluminum Pipe 6x91mm Grey (2) (rear upper)
Axial Threaded Aluminum Pipe 6x106mm Grey (2) AX30516 (rear lower)
RC4WD 55mm (2.17") Internally Threaded Aluminum Link (Black) (1) Z-S0319 (steering)
RC4WD 65mm (2.56") Internally Threaded Aluminum Link (Black) (2) Z-S0316 (front upper)
RC4WD 87mm (3.43") Internally Threaded Aluminum Link (Black) (2) Z-S0312) (front lower)
Over $1400.00 Invested, not including substantial labor.
FREE SHIPPING!
Other truck and accessories not included.
Tags: Axial scx10 scx-10 scx Dingo Honcho Cherokee scaler 1/10 scale 4WD RC rock crawler rock Crawler truck car RC4WD Tekin motor rpp hobby junfac vanquish proline Pro-line masher hot racing rccrawler tsccrawler tsc 3racing twenty1eleven rcsparks wraith xr10 sx Radio Electric Control Nitro gears Savage Baja Team Race Cars 2.2 1.9 1.55 clodbuster clod mud-slingers stamped steel wheels tamiya tires wheels bead locks bead lock radio control lipo mud thrashers
FREE SHIPPING!
