Unique Custom Built Rare Jeep Grand Cherokee WK Scale RC Truck w/8ch Radio FREE SHIP
My Feedback: (28)
Unique Custom Built Rare Jeep Grand Cherokee WK Scale RC Truck w/8ch Radio FREE SHIPPING!
Includes custom made Floor Pan with wheel wells, scale accessories and Radio Controlled Light System. Ready to Run!
This Truck is being listed along with my other custom trucks in my other listings.
This truck has over 279,000 views on YouTube so you may have seen it before, along with my other rigs.
They were used to film these videos and were then placed in an enclosed glass case for display.
Each truck is suspended on stands (included) at each axle to keep the tires from flat spotting.
They all have added weight to the inner wheels for better traction while climbing. Front having more weight than the rear.
Link to Build Video.
(7 min 54 sec)
Link to YouTube Videos. https://www.youtube.com/playlist?lis...0C1CFB94F82983
The following is a list of just some of items used in the build:
Axial SCX10 Frame Set AX30525
Axial Transmission AX30487
Axial Steel Outdrive Shaft Set AX30435
Axial Slipper Clutch AX10/Scorpion AX30414
Axial Spur Gear 48DP 87T AX30672
Axial Pinion 48DP 20T AX30578
RC4WD T-Rex 44 Mini Front Axle Z-A0071
RC4WD T-Rex 44 Mini Rear Axle Z-A0069
RC4WD 4 Link Mount for T-Rex 44 Mini Axle Z-S0511 (2)
RC4WD T-Rex 44 Front Steering Links Z-S0147
Rare Jeep Grand Cherokee (WK) HardBody
Custom made Floor Pan with wheel wells
Custom Hidden Velcro Body Mount System
Tekin FXR ESC/35T Crawler Motor Combo
Duratrax Onyx LiPo 2S 7.4V 5000mAh 25C Hard Case Deans
W.S. Deans Male Ultra Plug (1) 1302
W.S. Deans 2-Pin Ultra Plug 1300
FlySky FS-GT3B 2.4ghz R/C Transmitter Controller. Upgraded (hacked) with Custom Version 0.6.1 firmware (8 channels),
Voltage Regulator, and 4-Pin flash header mods.
FlySky FS-GR3C 3ch 2.4ghz Receiver
Hitec HS-7775MG Digital Low Profile Metal Gear Coreless steering servo
Ofna CNC Aluminum Servo Arm 24T Hitec
RC4WD Mud Thrashers 1.55 Scale Tires (4) Z-T0100
RC4WD Stamped Steel 1.55 Stock Black Beadlock Wheels (4) Z-W0036
Axial Aluminum Hex Hub Narrow 12mm Black (4) AX30427
RC4WD 1.5 & 1.7 Steel Wheel Hex Hub with Brake Rotor (4) Z-S0529
RC4WD Scale Wheel Lugs for 1.55 Wheels (24) Z-S0104
RC4WD Scale Aisin/Yota Style Hubs (2) Z-S0196
RC4WD Scale Rear Hubs Z-S0175
RC4WD Mega Truck Universal Shaft (92mm to 130mm) VVV-S0003 (Front)
RC4WD Mega Truck Universal Shaft (80mm to 110mm) VVV-S0038 (Rear)
RC4WD The Ultimate Scale Shocks 90mm (Red) (4) Z-D0002
Custom front lower shock mounts (2)
RC4WD Super Bright Scale Light System 2 Z-E0019
Tungsten Filament Headlights like full scale.
LED taillights
Rcexl Optio on/off switch (for light system)
Front and rear 4-Link Suspension
All aluminum links including:
RC4WD 33mm (1.30") Internally Threaded Aluminum Link (Black) (2) Z-S0323
RC4WD 40mm (1.57") Internally Threaded Aluminum Link (Black) (2) Z-S0322
RC4WD 55mm (2.17") Internally Threaded Aluminum Link (Black) (2) Z-S0319
RC4WD 65mm (2.56") Internally Threaded Aluminum Link (Black) (2) Z-S0316
RC4WD Miniature Scale Hex Bolts (M2x5mm) (Black) (20) Z-S0625
RC4WD Miniature Scale Hex Bolts (M3x8mm) (Silver) (20) Z-S0695
Scale off-road Hold Down Straps with Metal Buckle (Yellow) (1) V-SD00017
Over $1300.00 Invested, not including substantial labor.
FREE SHIPPING!
Scale figures not included.
Tags: Axial scx10 scx-10 scx Dingo Honcho Cherokee scaler 1/10 scale 4WD RC rock crawler rock Crawler truck car RC4WD Tekin motor rpp hobby junfac vanquish proline Pro-line masher hot racing rccrawler tsccrawler tsc 3racing twenty1eleven rcsparks wraith xr10 sx Radio Electric Control Nitro gears Savage Baja Team Race Cars 2.2 1.9 1.55 clodbuster clod mud-slingers stamped steel wheels tamiya tires wheels bead locks bead lock radio control lipo mud thrashers wk
LED taillights
FREE SHIPPING!
