NIB Dr. Mad Thrust 90mm 12 Blade Alloy EDF 1250kv - 3700w (8S)
![](/forum/images/badges/trading_plus_member.png)
Up for sale is the Dr. Mad Thrust 90mm 12 Blade Alloy EDF 1250kv - 3700w (8S) NIB. comes with 90mm mounting straps.
Features:
o Pre-assembled
o Factory dynamically balanced
o High power with superior cooling
o High quality construction
o Fully serviceable
o Fast to fit
o No housing distortion
o Cast metal rotor
Specs:
Weight (Total): 615g
MAX RPM: 37000
MAX Power (10sec.) Watt: 3700
Continuous Power Watt: 3300
Motor Size: B4082
Current: 112 Amp
Max Voltage: 30v (8s)
Thrust Power: 4.5kg
Inner: Diameter: 92mm
Outer Diameter: 94mm
ESC (timing): High
Buyer pays shipping. If using PP use friends/family or add 3% when using the business method.
Features:
o Pre-assembled
o Fully serviceable
o Fast to fit
o Cast metal rotor
Specs:
MAX RPM: 37000
Motor Size: B4082
Current: 112 Amp
Thrust Power: 4.5kg
ESC (timing): High
