Rare Futaba S9152 Digital Mega High Torque Servo FREE SHIPPING! (3) Available
My Feedback: (28)
(3) Available $109.95 ea.
These are Out of Production and very hard to find.
This is the Futaba S9152 Mega High Torque Metal Gear Dual Ball Bearing Digital Servo.
Comes with "J" Connector Pre-Installed.
FEATURES: Heavy duty wiring handles higher current loads
New metal center casing helps dissipate heat and is designed to be water and dust resistant
Coreless motor. High Torque. Metal gear
INCLUDES: One Futaba S9152 Digital Rudder Servo / Two rectangular grommets / Four brass bushings / Four 3mm x 15mm self tapping phillips head mounting screws / One 1.2" (30mm) diameter round horn / One 3.5" (88mm) diameter star shaped six point horn / One 3.9" (98mm) diameter four point horn / Metal and nylon gears
SPECS: Speed: .24 sec/60° @ 4.8V, .19 sec/60° @ 6.0V / Torque: 222 oz-in @ 4.8V, 278 oz-in @ 6V / Weight: 3oz (85g) / Length: 1.91" (48.6mm) case only / Length: 2.54" (64.6mm) including mounting tabs / Width: .99" (25.2mm) / Height: 1.56" (39.7mm) / Output Shaft Diameter: 8mm / Distance between mounting hole centers same side: .55" (14mm) / Distance between mounting hole centers opposite side: 2.35" (59.6mm)
FREE SHIPPING!
USA ONLY.
FUTM0212
FREE SHIPPING!
USA ONLY.
FUTM0212
