Stug IV, work in progress
WA
This is Stug 4 project I started a long time ago and will never get around to finish.
Modified Heng Long PZR 4 lower hull, I think the upper is from AsiaTam, but not sure. No electronics other then Heng Long "apple", and Tamiya recoil unit. Set up for gun tube traverse/lift when finished by using servos or available std products. Recoil unit is Tamiya and is the only electronic part included. Aluminum gun tube and cast metal hatch hinges and other bits. Comes with plastic track but will option with metal for additional $10.
Shipping is actual cost. for estimate use 4lbs weight, 10x10x18 box size. your choice of shipper. will come from zip 98363
