90mm F-86 Sabre EDF Upgraded Electronics
My Feedback: (21)
NitroPlanes 90MM EDF in good flying condition. It does have some rash but its all cosmetic. This is a blast to fly and everyone likes to se and hear it fly. Modifications include hard steel pins in the landing gear replacing the soft stock ones. Reenforced the gear mounts. The elevator surface extended about a half inch for better control. A rod extending from one elevator through to the other to control flex. Dubro hinged control surfaces. Upgraded electronics Castle, HET motor, composite fan and Eflight servos. Removed "The Huff" and replaced it with BANG BANG decals.
The gear and doors are sequenced and the air breaks work!!
The JetFan 90 sounds awesome and she is graceful in the air. Landing is smooth and gentle when flaps are used.
Forum: http://www.rcgroups.com/forums/showthread.php?t=
1552199
YouTube video of this jet:
Airframe: Nitroplanes
Motor: HET Typhoon 700-60-1865
Fan: JetFan 90 V2
The JETFAN 90 is a high performance fan custom built in Austria, featuring a 9 blade
rotor made up of precision hub and GRP molded blades, this rotor is one of if not the
toughest 90mm on the planet! Housing features carbon fiber shroud with GRP molded
stator assembly.
Servos: 12 EFlight EFLR7140 13g
ESC: Castle Creations ICE 100 with separate 10AMP BEC
Batterys (included): 4 Turingy 5000 3s
Receiver (NOT included): 8ch minimum
LOCAL PICK UP ONLY
1552199
Fan: JetFan 90 V2
stator assembly.
LOCAL PICK UP ONLY
