jetcat pht3
jetcat pht3
up for sale is a netcat pht3 built using a jetcat p80 engine as they used in the factory. engine runs well. i constructed the side pieces to fit pod and boom setup. all you need is your servos and and gyro. ill give you a head you have to choose flybar or flybarless. am also giving you the ecu pump and fuel valves and a propane tank with fuel tubings. also i do free sercive for you when that time comes. just pay for shipping. have less than 5 minutes on it.
Pht3
How is that going to work with the exhaust shooting straight out the back? My jetcopter had an exhaust pipe that diverted equal amouts on exhaust thrust left and right for a net zero effect. Where are the tanks mounted?
