NIB JTM XXX Jet EDF or Turbine capable
NIB JTM XXX Jet
I have too many projects and have to get rid of this. I have a brand new JTM XXX jet. Box has been opened only. It is suitable for 110mm-120mm edf or 60N-100N turbine. It has full ducting for EDF setups or open ducting can be used. This XXX Jet is design for 110-120mm size electric ducted fan units.It features a fully composite fuselage and wing with retract hard points pre-installed in the nose and retract hatches pre-cut in the wing.
This model comes completely pre-painted with decals applied and protected by a clear coat, hatches are pre-assembled.
Content:
Fully painted composite fuselage (Airex and fiberglass)
Live hinges all around
Fully assembled vertical fin and pre-installed intake ducting
Clear canopy with pre-installed hinges
One-piece fully painted composite wing with aileron, flap and retract hatches
Exhaust ducting sheet, small parts, hardware pack.
Wing Span....................1490mm (58.5'')
Length...........................17000mm (67'')
Box new from manufacturer and no damage noted. However it is purchased as is. Retracts, electric brakes and suitable scale oleo struts are available as option $300.00.
Tone
